Thread: Wet rear right floor
    Jun 2020
    Winchester
    Engine : Z32SE
    Default Wet rear right floor
    Hi All,
    I have a problem with my 2004 Vauxhall Signum. There is water ingress at the rear left side (edited) footwell from somewhere. There is no water anywhere else. Once the drain in front of the cabin filter got blocked but on that occasion the front carpet was also soaking wet. Touching around the edges of carpet seems like the door side "wall" is wet, so probably coming from somewhere there. I checked the drain holes on the bottom of the rear door, pushed a stick in, moved it around but there was no sudden gush of water. I suppose it is draining off the door without issues. Somewhere read about aerial seal but the roof lining is not wet. There is no sign of water in the boot. Spare wheel dry. Used to have a Golf IV and a Leon, both were leaking through the door panels, had to re-seal all the door. Can this also be a problem with the Signum? Never heard of it. Thanks in advance!
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    26 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Aerial gasket, roof rails are the common failures.
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2023 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
    Jun 2020
    Winchester
    Engine : Z32SE
    Quote Originally Posted by Jon1796 View Post
    Thank you! Aerial gasket: would the roof not be wet as well then?
    Roof rails: where would the water come in? In-between the front and rear doors behind the plastic panels? Thanks!!
    Sep 2015
    Norwich
    26 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    The gasket it will make roof damp but you wouldn't really know untill you dropped it. The rails are riveted on and have seen others complaining off leaks turned out to be that.
  1. New rear calipers pedal sink to floor
    By Kanti83 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2019, 14:13
  2. Angle of the rear seats from the boot floor
    By Drogen24 in forum Bodywork & Interior
    Last Post: 31st December 2018, 13:40
  3. Nearside rear floor soaking??
    By nike in forum Bodywork & Interior
    Last Post: 26th February 2011, 00:46
  4. FAO Estate owners - Rear floor mats?
    By MadOnVaux! in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2011, 17:31
  5. help wet passengers floor front and rear
    By bear1966 in forum Bodywork & Interior
    Last Post: 27th April 2010, 19:26
