Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Z19DT Fuel Pressure Dropping
  1. #11
    Full Member
    Dec 2019
    Midlands
    Vehicle : Vectra C Estate
    Engine : Z22YH
    Year : 07
    I’ve never done one so can’t advise but if it’s easy to do it’s the first port of call as that small part does the controlling of the pressure bit. If the pump was gone it wouldn’t be able to make the higher pressures? Look out for relearning though.
    Looks easy enough from when i was visually inspecting all the pipe work for leaks the other week. I had the same thoughts, that if it were the pump; it would never make the higher pressures even if you were to roll into it. But from the live data, it does make the full pressures when you ease into it, it lower gears anyway. Once you're into 4th gear it'll keep going without any issues.
    I'm sure somebody else will chime in if I'm incorrect, but i don't believe you need to do any re-learning for a replacement Regulator on this engine. I do have the tools required to do it if necessary, ill have a poke about in the Fiat Diag software. That's if a genuine GM fuel filter doesn't cure it.
    Thanks again for your input, its helpful to have somebody to bang heads with.
    Vectra C 2.2 Direct Elite Estate Misty Morning Blue
    Grande Punto Sporting Z19DT Tom Procko Tuned 170BHP Imola Yellow
    Tech2, GDS2, Fiat/Alfa MES and Vauxhall Security code retrieval services. Located in West Mids.
  2. #12
    Full Member
    Dec 2019
    Midlands
    Engine : Z22YH
    Year : 07
    Update: Genuine GM fuel filter did NOT resolve the issue unfortunately.
  3. #13
    Apr 2016
    Ipswich
    87 Post(s)
    Vehicle : Vectra C Saloon
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    replace pump as this is one of the symptoms of a HPFP on it's way out... and while you are having to replace, you might want to decide to actually make it compatible so you don't have to tank premium fuel... the info is on the forum so have a look, it's not cheap though.
  4. #14
    Dec 2010
    London
    7 Post(s)
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Are you on about the 2.2 petrol cos this thread is about a 1.9 8v diesel.
  5. #15
    Apr 2016
    Ipswich
    87 Post(s)
    Year : 2003
    Mileage : 140000
    Quote Originally Posted by troutybrown View Post
    yes as i stupidly only looked at what engine he had in his profile... my bad
  1. z19dt - oil pressure light on for a minute after startup
    By kaliope in forum Engine & Drivetrain
    Last Post: 28th May 2020, 20:28
  2. Does anyone know max boost pressure z19dt
    By Vectra kris in forum Engine & Drivetrain
    Last Post: 27th August 2014, 09:39
  3. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
