Results 1 to 10 of 15
Thread: Z19DT Fuel Pressure Dropping
    Full Member
    Dec 2019
    Midlands
    Vehicle : Vectra C Estate
    Engine : Z22YH
    Year : 07
    Default Z19DT Fuel Pressure Dropping
    Hi All,
    I own a Vectra C Estate and frequent the forum a lot, so i know there's plenty of guys on here than know their stuff. The vehicle in question isnt a Vectra but uses the same engine.
    My missus owns a 1.9 (Z19DT 8V) 2009 Grande Punto, EGR delete, FMIC and mapped by Tom Procko. Currently seeing drops in fuel pressure when you accelerate hard. (Getting a Fiat specific P0091-22 Fuel Pressure high pressure pump input regulator code).
    Ive included a photo below of the live data when the fault happens, in this instance i was cruising at 1.5k rpm in 3rd gear and then put my foot to the floor on the accelerator. This shows the desired fuel pressure spike as it should, actual fuel pressure drops but then tries to climb to where it should be. It then puts the EML light on and goes into limp mode. Limp mode can be cleared by cycling ignition. Accelerating steadily doesn't produce the fault.
    Live Data
    https://i.imgur.com/EbJdVKz.png
    Fault Code
    https://i.imgur.com/LETasqg.png
    I've read a lot of the posts regarding fuel pressure fault, but none seem to include any live data and seem to just throw parts at the vehicle. Any ideas guys?
    PS: Couldn't insert the images directly, was getting an "invalid file" error.
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    336 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Any service info? When was the fuel filter changed and what brand?
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Full Member
    Dec 2019
    Midlands
    Engine : Z22YH
    Year : 07
    Quote Originally Posted by Dog_Book View Post
    Vehicles currently on 65k miles, owned since 30k miles. Full Fiat service history every year since new, until our ownership. Roughly 9 Fiat stamps.
    Since our ownership, its had engine oil, oil filter, air filter changed every 6-8k miles. Fuel filter changed every other service. Gearbox refurbed at 61k miles (good old M32).
    Just checked invoice and the last Fuel filter was September last year at 60k miles and it was a Crossland branded filter. The filters on the Grande Punto use the same metal canisters you find on the 1.9cdti Combo D van (https://www.ebay.co.uk/itm/353410730694)
    Cheers.
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    25 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    On pictures I find if you edit it save then add works.
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2022 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
    Oct 2013
    Derby
    336 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    You could also ask Tom, I know its not his problem but as he does live data mapping he might know pretty quickly. In all my time with these engines I dont know if the SCV is a separate part or how the pressure is controlled like other common rail diesels.
    Full Member
    Dec 2019
    Midlands
    Engine : Z22YH
    Year : 07
    Thanks mate, already dropped Tom a message, he suggested renewing the fuel filter first as a precaution, but it could be the fuel pump on the way out. Which would be odd as the cars only done 64k miles and had more fuel filters than probably 80% of cars with this engine. Somebody else on here may be able to confirm, but I'm led to believe the regulator is on the pump itself and ECU controlled. There's a lot of used pumps for sale with the regulator included, so failing the filter fixing the issue I might need to bite the bullet and replace them both. Use pumps seem to go for £30 to £100 not the end of the world if it doesn't solve it.
    Doesn't seem too difficult to replace the pump and looks to be possible without removal of the timing belt. Will get a genuine GM fuel filter on order and update my post when its been fitted.
    Cheers.
    Vectra C 2.2 Direct Elite Estate Misty Morning Blue
    Grande Punto Sporting Z19DT Tom Procko Tuned 170BHP Imola Yellow
    Tech2, GDS2, Fiat/Alfa MES and Vauxhall Security code retrieval services. Located in West Mids.
    Sep 2015
    Norwich
    25 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Just a thought as I don’t play with deso’s does rail pressure drop straight off when engine has stopped then I would look at leaking injectors and pressure release on rail.
    Oct 2013
    Derby
    336 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Sounds like the SCV as it’s making the commanded pressure but is slow to react. The control valve is held on with 3 bolts I believe but I’d assume it needs learning once replaced. Don’t have a Cdti infront of me so can’t plug my tech2 in to check if there’s an option but my Mokka certainly has it as I just replaced mine.
    Full Member
    Dec 2019
    Midlands
    Engine : Z22YH
    Year : 07
    Quote Originally Posted by Jon1796 View Post
    I haven't checked rail pressure when the engine is stopped via live data, at idle fuel pressure is basically the same as desired fuel pressure. I have measured injector quantity deviation/correction and across a 5 mile drive the maximum deviation across all 4 injectors was +2 and -1. They all seemed to be roughly the same. Which I would think would rule out leaking injectors?
    Slow to react is what i am seeing in live data, yes. If you ease into a hard "pull" having your foot to the floor by 3k rpm, measured fuel pressure will always stay with desired, all the way to the hardcut rev limiter. But why it slow to react I haven't been able to work out. In theory "slow to react" could be caused by both the Pressure Regulator and the Fuel Pump?
    Perhaps you are right and it might be wiser to replace the Regulator before the fuel pump since it is easier.
    Oct 2013
    Derby
    336 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I’ve never done one so can’t advise but if it’s easy to do it’s the first port of call as that small part does the controlling of the pressure bit. If the pump was gone it wouldn’t be able to make the higher pressures? Look out for relearning though.
  1. z19dt - oil pressure light on for a minute after startup
    By kaliope in forum Engine & Drivetrain
    Last Post: 28th May 2020, 20:28
  2. Does anyone know max boost pressure z19dt
    By Vectra kris in forum Engine & Drivetrain
    Last Post: 27th August 2014, 09:39
  3. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
