Likes Likes:  1
Results 1 to 10 of 16
Thread: Very High Fuel Consumption
    Aug 2011
    Dudley
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTI 150BHP
    Mileage : 170,000
    Default Very High Fuel Consumption
    Guys,
    Note been on here for some time as all things have been good. However, the car is a Vectra C Estate 1.9CDTI with a very high fuel consumption. To give an idea I've just done 89 miles on £40 of motion lotion. Now a few things have happened which may lead to the root of the problem, but I need some expert advice to narrow down the problem.
    1 The turbo was refurbished by Telford Turbo's and runs just fine. It was done because it was passing a lot of oil.
    2 At the same time as doing the turbo I cleaned out the throttle body that was full of oil. Then noticed the wires leading to the throttle body had perished so cut out the bad wire soldered, and heat shrunk to make a good job. Expected to get a management light on but no all was good.
    So, I used the usual software to operate the throttle and the flap moved, however when I look at the position of the flap the feedback doesn't change. So, does the ECU use this feedback for metering air/fuel ratio ?
    Hope you guys can help.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    i'd be checking what the state of the MAP sensor is, as you didn't state you've cleaned it.
    Aug 2011
    Dudley
    Mileage : 170,000
    Quote Originally Posted by northpole View Post
    Thanks for the reply, so checked it this afternoon and to be honest it was cleaner than I expected it to be. Give it a blast with some carb cleaner to remove the oil mist on it and replaced it.
  4. Likes northpole liked this post
  5. #4
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    Did it solve the problem though?
  6. #5
    Aug 2011
    Dudley
    Mileage : 170,000
    No, it hasn't made any difference to the fuel consumption.
  7. #6
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    oke so we are going to need some extra information:
    have you blanked the egr?
    have you removed the intake flaps?
    is your exhaust smoking, and if so what is the colour of the smoke?
    when did you change the fuel filter?
    what size wheels are you running and what's the tire pressure ?
    what is the state of the rear calipers and disks?
  8. #7
    Regular Member finn67's Avatar
    Jun 2013
    Lancashire
    Trim : VXR
    Engine : 2.8T
    Your mileage to fuel ratio suggests one thing only, there's diesel leaking somewhere between the tank and the injectors. You'll need a second person here ... Pop the bonnet - remove big plastics to give you a better view ... engine idling ... scour the bay area for any diesel anywhere outside of piping or filter --- nothing? ask your assistant to take it to about 2,000 revs - then 3,000 ... by now, if you have a leak from the injector/seal or leak off pipes then you will be seeing it now. It may only be a small splash at the minute but under torque load driving it could be pouring out ...
  9. #8
    Aug 2011
    Dudley
    Mileage : 170,000
    Response in blue.
    have you blanked the egr?Yes, and it's mapped out
    have you removed the intake flaps? No
    is your exhaust smoking, and if so what is the colour of the smoke No
    when did you change the fuel filter? 9 Months ago
    what size wheels are you running and what's the tire pressure 17" and 36Psi
    what is the state of the rear calipers and disks? Good condition
  10. #9
    Aug 2011
    Dudley
    Mileage : 170,000
    Quote Originally Posted by finn67 View Post
    I thought about that some weeks ago before posting on here but couldn't find a single leak anywhere or even smell diesel. I'm baffled because this only started after re-fitting the turbo from being re-cored.
  11. #10
    Aug 2011
    Dudley
    Mileage : 170,000
    <br><br>I thought about that some weeks ago before posting on here but couldn't find a single leak anywhere or even smell diesel. I'm baffled because this only started after re-fitting the turbo from being re-cored.<br>
    <br>
  1. Cdti 120 high fuel consumption
    By jiffy1986 in forum Engine & Drivetrain
    Last Post: 24th April 2013, 11:05
  2. Replies: 1
    Last Post: 22nd October 2012, 07:55
  3. Intermittent high fuel consumption
    By wookie in forum Engine & Drivetrain
    Last Post: 26th April 2012, 22:10
  4. why the high fuel consumption?????
    By richje100 in forum Engine & Drivetrain
    Last Post: 27th March 2011, 20:28
  5. Fuel Consumption seems high, Signum 2.0 Deisel
    By Mad_Matt in forum Engine & Drivetrain
    Last Post: 22nd February 2008, 19:14
