Thanks Thanks:  1
Likes Likes:  2
Thread: Side light bulbs
    Forum Moderator FIL 4822's Avatar
    Central England
    Vehicle : Vectra VXR, VW Tiguan R-line Tech, Vivaro.
    Trim : Nav
    Engine : Various
    Year : 1 A.D
    Mileage : Rising
    Default Side light bulbs
    Can anyone recommend some sidelight bulbs ?
    Looking for some ‘white light’ as the ones fitted are yellow compared to the headlights.
    Post me a link to something decent please.
    Regular Member JagRigger's Avatar
    Norfolk
    11 Post(s)
    Engine : 1.8 VVT
    Mileage : ... 275K!
    Without going down the LED route I found these to be pretty good :
    501 W5W 3500K Whiter Car Bulb Halfords Advanced Twin Pack
  3. Thanks FIL 4822 thanked for this post
    Likes NeilGo liked this post
  4. #3
    Central England
    Trim : Nav
    Engine : Various
    Year : 1 A.D
    Mileage : Rising
  5. #4
    Engine : 1.9 CDTi
    If you want to fit leds you can by fitting a relay
  6. #5
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    87 Post(s)
    Vehicle : Vectra C Saloon
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Quote Originally Posted by lee gsi View Post
    LED upgrade bulbs in the normal headlights are now an immediate MOT fail, unless you get upgrade LED projectors and leave the type approval markings on the projectors housing for the MOT tester to clearly see. HID's are also a immediate fail now too unless you have Upgraded HID projectors with the type approval markings insight for the MOT tester to see if it doesn't have that don't even bother, and keep the lot halogen, the only bulb inside the headlight that you can swap to LED without them failing the MOT test is the W5W aka position/driving light as it's doesn't put out enough light to blind anyone (it's position inside the reflector means it doesn't cause any glare)
    I'd say read the online MOT rules, if you have upgraded led bulbs done right (no warning messages or flashing) and you passed MOT you are lucky, but most MOT stations will fail the car on the bulbs, unless you have upgraded the projectors (and if you do so they come with their own approved LED bulbs, canbus error free resistors etc all in one unit)
  7. #6
    Engine : 1.9 CDTi
    I have HID's in mine and just swap them back to the normal bulbs if they fail them.
    I know its an MOT fail if the tester is sticking 100% by the book book but having HID's in the beam is perfect and no brighter than other newer cars.
  8. Likes bibu16v liked this post
  1. Replies: 1
    Last Post: 3rd July 2013, 19:41
  2. Side light bulbs
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2011, 17:21
  3. Side light bulbs
    By howd3y in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2009, 22:15
  4. LED side light bulbs..
    By AngryDog in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2009, 16:25
  5. side light bulbs
    By linley85 in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 20:40
