Thanks Thanks:  1
Likes Likes:  4
Thread: 2.8 v6 Turbo cam/crank DTC's
    New Member EliteBadger's Avatar
    Jul 2022
    Far North
    Engine : 2.8 v6 Z28-NET
    Default 2.8 v6 Turbo cam/crank DTC's
    My ex police 2.8 v6 Turbo has started showing a P0016 "Crank/Camshaft Mis-align/sync" DTC recently, driven fine for a couple of thousand miles.
    Today when I accelerated hard, the MIL started flashing and the engine ran rough, she then started showing a P0306 "Cylinder 6 missfire" After stopping and starting the engine it is smooth again.
    Is changing the camshaft position sensor the first port of call? or should I be looking at other things too?
    If yes to changing the senser, can any of you tell me where it's located on the v6 turbo? I've found a vid that shows it on the standard V6 but that looks different to the turbo. Cheers.
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    24 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    ​​​VECTRA VXRs BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2022 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
    Jul 2022
    Far North
    You sire, are a scholar and a gent, I raise my chalice to you!
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    333 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by EliteBadger View Post
    That first picture isnt a camshaft sensor, and you mention the 'standard V6'. The standard V6 we are talking about always has a turbo on it no Vectra/Signum ever made didn't.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Jul 2022
    Far North
    Aye Dog_Book the vid I mentioned was actually australian ******** so ignore that part I just wanted the location on the NET engine. Looks like I may aswell get the chains done whilst I'm there.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    81 Post(s)
    Vehicle : Vectra C Saloon
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    -judging by the title he wanted to know the position of both the crankshaft and the cam se6nsors on the z28net, so to make it clear:
    - first picture is crankshaft sensor
    - second picture is camshaft sensors... yes it has 2, bank 1 and bank 2 have their own sensors...
    but since you know it misfires only on cylinder 6, you might get away with just replacing that one.
  7. Likes bibu16v liked this post
  8. #7
    Jul 2022
    Far North
    Quote Originally Posted by northpole View Post
    Cheers Northpole I had sussed that but thanks for clarifying.
    Can any of you tell me if the ECU is going to need to be told to "relearn" the sensors when I change them or should it not notice?
    Last edited by EliteBadger; 25th September 2022 at 19:50. Reason: additional question
  9. #8
    Full Member
    Dec 2019
    Middle
    Trim : SW
    No adaption time for crank, cam, temp sensors
  10. Thanks EliteBadger thanked for this post
    Likes bibu16v, northpole, EliteBadger liked this post
  11. #9
    Apr 2016
    Ipswich
    81 Post(s)
    Mileage : 140000
    Quote Originally Posted by Propeller View Post
    perfectly answered
  1. crank sensor and eml
    By baines23 in forum Engine & Drivetrain
    Last Post: 18th October 2016, 17:48
  2. Crank Sensor on a 3.2 V6 ?
    By Woody in forum Engine & Drivetrain
    Last Post: 15th April 2013, 21:49
  3. Crank Sensor
    By GCusdin in forum Engine & Drivetrain
    Last Post: 13th December 2012, 12:13
  4. crank pully
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 19th June 2011, 22:39
  5. crank pulley
    By andyc#elite in forum General Chat
    Last Post: 18th November 2007, 09:12
