Results 1 to 4 of 4
Thread: Gearbox selector.need nuetral.
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    Default Gearbox selector.need nuetral.
    Hi ppl. It's that annoying person again lol. My advice I need is to get gearbox in neutral to replace the gearbox selector that fits into gearbox. Any advice on how to get neutral so I can finally get car moving. Vauxhall insignia hatchback mk1 2009 1.8 m32 gearbox 6 speed
    Apr 2016
    Ipswich
    80 Post(s)
    Vehicle : Vectra C Saloon
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    have a look in the topics below before you continue to do anything and mess it up.
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    Wonder if pushing clutch in will help out box in neutral ?
    Apr 2016
    Ipswich
    80 Post(s)
    Year : 2003
    Mileage : 140000
    right so have you removed the gear linkages already? Is the gearbox still in place ( connected up to the engine etc etc etc) ?
    A picture or 2 of the current situation will be easier than answering these questions...
    but if the lot is still connected, you just push the clutch down and pull the car out of the gear it is in...
    if you have disconnected the gear linkages from the gearbox.. well you can just move both those levers they both can be moved without using the clutch you'll soon find the car being in neutral, jack the car up both front wheels in the air so you can turn a wheel to find that when it's in neutral you can just turn them without any resistance.
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. gearbox selector arm
    By Bigsel74 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2016, 14:47
  3. Gearbox Selector arm
    By Bigsel74 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th July 2016, 14:41
  4. gearbox - gear selector loose -
    By cermi in forum Engine & Drivetrain
    Last Post: 25th May 2014, 09:38
  5. Vectra Revving in nuetral-any ideas?
    By sr310583 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th September 2009, 20:56
