Thanks Thanks:  2
Thread: Gearbox selector.need nuetral.
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    Default Gearbox selector.need nuetral.
    Hi ppl. It's that annoying person again lol. My advice I need is to get gearbox in neutral to replace the gearbox selector that fits into gearbox. Any advice on how to get neutral so I can finally get car moving. Vauxhall insignia hatchback mk1 2009 1.8 m32 gearbox 6 speed
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    81 Post(s)
    Vehicle : Vectra C Saloon
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    have a look in the topics below before you continue to do anything and mess it up.
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    Quote Originally Posted by northpole View Post
    Wonder if pushing clutch in will help out box in neutral ?
    Apr 2016
    Ipswich
    81 Post(s)
    Mileage : 140000
    right so have you removed the gear linkages already? Is the gearbox still in place ( connected up to the engine etc etc etc) ?
    A picture or 2 of the current situation will be easier than answering these questions...
    but if the lot is still connected, you just push the clutch down and pull the car out of the gear it is in...
    if you have disconnected the gear linkages from the gearbox.. well you can just move both those levers they both can be moved without using the clutch you'll soon find the car being in neutral, jack the car up both front wheels in the air so you can turn a wheel to find that when it's in neutral you can just turn them without any resistance.
  5. Thanks NeilGo thanked for this post
  6. #5
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    Hi there sorry my late reply. I had to remove gearbox as after I removed end casing the synchro ring on one of the shafts had slid off and the 3 bearings had come out. Also the 6th gear bearing is knackered. Once I get a puller I will be replacing the bearing(s) and putting it all together and back in motor. Will post update
  7. Thanks NeilGo thanked for this post
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. gearbox selector arm
    By Bigsel74 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2016, 14:47
  3. Gearbox Selector arm
    By Bigsel74 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th July 2016, 14:41
  4. gearbox - gear selector loose -
    By cermi in forum Engine & Drivetrain
    Last Post: 25th May 2014, 09:38
  5. Vectra Revving in nuetral-any ideas?
    By sr310583 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th September 2009, 20:56
