19th September 2022, 09:28
#11
What we should do collectively is stop trying to help until he shows the requested pictures... as @Dog_Book rightly pointed out already size of the nut doesn't make a blind difference as long as it fits over the thread properly...
@op
Show pictures or get no answer... up to you.
1st October 2022, 10:14
#12
Originally Posted by
northpole
@op
When you've bought and paid for this forum, THEN you can throw your weight around, make up pointless rules and in general be as unhelpful as possible. Until then, if you don't have something useful and accurate to say then find another task to occupy your time.
Please and thank you.
1st October 2022, 10:52
#13
LastOne
Something accurate? don't go complaining, you asked for it... stop being a keyboard warrior...(and i don't know if I stated this before, but I really don't care about your input regarding my replies)
Back ontopic:
point in this case he wants help get's asked for pictures so he can get a proper answer, than he doesn't put up pictures... without seeing what he actually is on about no one, can answer his question without just plain guessing. So pictures are needed, without them this is a pointless topic. So instead of everyone trying to guess, just wait until he shows the problem. Less for people to go through when they experience the same problem.
1st October 2022, 12:44
#14
@LastOne
It was requested here by some forum members, not only by @northpole, to post some relevant pics in order to get some proper help...as simple as that. No fuss. If there's some secrecy about what & how you're working that's fine, nobody will bother you again, no offence. My 2p opinion.
1st October 2022, 17:53
#15
If uploading pics is this issue then I've found imgbb.com really easy to use. Uploading photos from your phone is straightforward and the site provides a third party hosting link.
1st October 2022, 22:21
#16
Or just use tapatalk I find it’s normally at top when I load this forum.
12th October 2022, 18:41
#17
12th October 2022, 18:42
#18
13th October 2022, 11:08
#19
I would reuse the oem nut, that's what i did when i had to replace to wheel bearing.
13th October 2022, 11:25
#20
that drive shaft needs to be pushed in more, and if it doesn't want to come in more, I suggest you use the OEM nut, the collar on it will pull it all the way in without damage to the hub.
