Likes Likes:  4
Results 1 to 10 of 16
Thread: Drive shaft fitting help
    Oct 2018
    Aberdeen
    Trim : 150
    Engine : 1.9cdti
    Default Drive shaft fitting help
    So this morning i fitted a pair of vxr shafts to my 1.9cdti signum with f40 box on fitting them i noticed the end of the splines on the shaft don't sit flush to the end of the hub is this normal and the end 36mm nut doesn't have a collar or a washer like the original did just gauging if anyone has done this and added a washer to the end of the driveshaft. thanks
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    24 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    The only real difference I’ve seen for the shafts is the thickness in between the joints. Is it pushed in far enough. Got a few in garage splines length match.
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2022 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    333 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    If i could see it that would make a difference but i can't see from here
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Oct 2018
    Aberdeen
    Trim : 150
    Engine : 1.9cdti
    Quote Originally Posted by Jon1796 View Post
    The nut is a 32mm originally but a 36 on the vxr
    Oct 2013
    Derby
    333 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    32mm what? Height, outer diameter? I did ask for clarification but still no pictures so can’t comment.
    Oct 2018
    Aberdeen
    Trim : 150
    Engine : 1.9cdti
    Socket size for the nut
    Oct 2013
    Derby
    333 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    The socket size is completely irrelevant to whatever this issue is as the dimensions of the nut are not related to the socket size. This is the 3rd time I’ve asked for pictures in order to try and make sense of the issue.
    Sep 2015
    Norwich
    24 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Quote Originally Posted by Obakemono View Post
    as they all use the same abs unit(vxr and full can vectra c)don’t see why the nut is different size unless someone already changed it.
    Can’t see any difference between expect half can and full can. M22/M24
    Oct 2013
    Derby
    333 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    We will never know until we see the job, it’s just going round in circles making us think when we can’t even see it I’m afraid
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    32mm is the original nut but on the JR shafts it is a 36mm nut. The socket size doesnt matter
  1. Drive shaft again…
    By Jon1796 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2021, 12:11
  2. Inner drive shaft gaiter fitting help...
    By megsdad in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2015, 22:53
  3. so drive shaft
    By bionic in forum Engine & Drivetrain
    Last Post: 21st April 2014, 16:57
  4. drive shaft
    By andy treg in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2011, 17:04
  5. drive shaft
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2008, 12:44
