Thread: 2.0dti with 2.2dtr turbo map
    Jun 2015
    Budapest
    Vehicle : Vectra C 2.0 DTi
    Trim : caravan
    Engine : 2.0 DTi
    Default 2.0dti with 2.2dtr turbo map
    Hi,
    Has anyone done the 2.2dtr turbo swap and 2.2 factory map mod on a 2.0dti ? I already have the variable vane turbo on and I've found a place where they have access to all the factory maps but they want me to tell them exactly which map version to upload of which I have no idea. Or can it be any 2.2dtr version from a Vectra C ?
    Thanks for your reply in advance.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    it should be the Y22DTR version from a Vectra... the youngest file they can get their hands on, as there was a recall for the maps somewhere to stop the VP44 fuel-pump from killing itself prematurely. Funnily enough I just did all the research for it as I am looking for the turbo and the right map file myself.
    But it should run without the mapping of the Y22DTR if you got a tuning box that provides more fuel but doesn't look at boost levels. ( all of these tuning boxes for the DTI's are setup to maximize fuel but don't look at boost at all)
    Jun 2015
    Budapest
    Trim : caravan
    Engine : 2.0 DTi
    Thanks for your reply. I had the 2.2dtr map uploaded this morning. It didn't take more than half an hour. I hope you are wrong about the existence of suicidal VP44 maps, because I had no choice. Official Opel map downloads are tied to chassis number. Since the tuner could not come up with one he used a 2.2dtr one from his own database of cars he had worked on.
    The only problem I have now is that since I am on the 2.2 map the bluetooth OBD adapter does not connect to my car anymore which I would need to be able to monitor boost pressures and pressure spikes in Torque Pro to justify whether I need a manual boost control valve.
    All in all, I can't really tell you yet how it performs at higher revs since not being able to monitor boost pressures I didn't want to risk. I drove home light footed but it pulls harder and definately has more torque but the turbo kicks in at 2000rpm which I think is a bit high for a variable vane turbo but it might be fine tuned with the push rod later I assume.
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    Well I am quite certain about the map killing the pumps... actually it's not the map but the hardware that is inferior...I would take it apart if I knew it could take the bigger plunger but because the vp44 has extra electronics inside I left it alone... as there is no one who could tell me of it was possible to do it...
    But yeah afaik you should be able to dail the boost back a bit to start earlier, just don't go crazy and do it in steps.
    Ps you should put your foot down otherwise you'll never know.
  1. 2.0dti turbo question
    Last Post: 20th January 2010, 23:11
