Results 1 to 3 of 3
Thread: 2.0 DTI Charging problems
    Feb 2020
    Staffordshire
    Trim : CLUB
    Engine : 2.0 DTI
    Default 2.0 DTI Charging problems
    Hi, I own a 2004 pre-facelift Vectra Estate. I'm having charging problems. The battery keeps going flat, after testing it with a multimeter the alternator was dead, brought and fitted a new one tested again and it was giving between 14-15 volts under load. A week later flat battery and again the alternator is not charging the battery. I used 2 multimeters one on the batter and one directly on the alternator to see if there was a drop between the two. The alternator reading was 0.7 volts? I have noticed that the second wire on the alternator (not the battery wire) looks like it has been replaced, does this wire turn on the alternators voltage regulators?
    Regular Member CDTIauto's Avatar
    Dec 2021
    Whitchurch Shropshire
    Engine : 1.9 cdti 150
    Mileage : 103000
    Try a fresh battery, some alternators do not charge if the batteries iffy
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    And if that doesn't work if it was a refurbished one bring it back... worst-case it is the regulator that is gone ( it's a cheap part) but if you bought a new one it should be working.
  1. Vectra Charging problems
    By Pinkywafer in forum Electrical & ICE (including SatNav)
    Last Post: 24th July 2021, 07:26
  2. Steering and charging problems
    By Brodie in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2018, 12:21
  3. Charging Problems
    By jcumming in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2010, 22:57
  4. K & N re-charging
    By Johnytuono in forum Diesel Engine related
    Last Post: 14th February 2007, 21:49
