Results 1 to 10 of 13
Thread: Vibration/Steering Wobble
    Fife
    Default Vibration/Steering Wobble
    Since getting my 3.0 CDTi Signum a few months ago, I have trouble with a slight(annoying!) vibration doing about 70mph. I've had the wheels balanced twice and it makes a slight difference but its still there. I've also swapped the front and back wheels and had them re-balanced, but its still there.
    Could there be something else wrong or do I need a complete new set of tyres?
    Thanks,
    Decho
    Regular Member surreyl31's Avatar
    Feb 2007
    somerset
    dont quote me but could be track rod end worn i had the same problem on my t reg rover 400
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Yeah, check your tie bars and make sure the tracking is spot on.
    Feb 2007
    somerset
    is there any play in the ball joints?
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    If there is, the ball joint is part of the tie rod assembly which costs about £22. Vx will charge you £400 to change said because they want to drop the sub frame?!? Took me 45 minutes to jack the car, remove the wheel, change the tie rod, put the wheel back, drop the car down, re-align the wheels (including three test drives) and put all the tools away. So you might want to do it yourself if that's what it is.
    Feb 2007
    somerset
    i agree its easy to do
    Fife
    Sorry, I'm not very technically minded when it comes to this. The car is only 18 months old and done 15k miles - I'm not the first owner however. If this is the fault, would this be covered by warranty?
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Should be. The job requires one adjustable spanner (the 35mm one from Halfords does nicely) and the tools in the boot to remove the wheel.
    Don't know if that's what it is yet though, have you been in to Vx with it?
    Feb 2007
    somerset
    i would of thought so i think its three years warranty
    Fife
    Yep, been to my local Masterfit and reported it when it had its first service. They had a go at balancing - slightly better but still there. I've read on other posts that they need to be very precise then balancing them on the Vectra/Signum.
    Excuse my ignorance but how do I test for play in the ball joints.
    I may take the car to my local independent garage for a look - they are excellent and always do a good job.
    I'm reluctant to buy new tyres if this is not going to improve things.
  1. Engine vibration/wobble 3.0 V6
    By h00per in forum Engine & Drivetrain
    Last Post: 2nd December 2010, 21:24
  2. Steering wheel vibration/wobble
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 24th September 2010, 20:23
  3. Wheel wobble/vibration Please help.
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2010, 18:50
  4. Help, Wheel wobble/vibration
    Last Post: 7th July 2010, 20:40
  5. steering wheel wobble/vibration
    By trucker in forum Insignia car chat
    Last Post: 3rd June 2010, 21:20
vectra c steering wobble
