I’ve found a Vauxhall Vectra Estate. Any help or advice on it would be great:
https://www.autotrader.co.uk/car-det...02207157813797
3.2 - belt may need changing soon, so check when it was last done. It's surprising to see leather seats in a plod car, usually they had cloth. The paintwork will never have been polished whilst it was plod-owned, just jet washed, or even worse, scrubbed with a water-fed brush that gets thrown on the floor and collects grit. Trim and carpet inside the boot is often butchered in the estates, to make space for various lock boxes etc that plod use. Plus often the extra wiring they have is removed really crudely, giving electrical issues.
the car has had 5 owners since... i don't think there will be any surprise electrical issues with it.. just your standard vectra ones, the 3.2L specific problems and the fact that the old owners might got rid because it needs the timing done or something else that is expensive to do at garages.
car looks to be in good cond for age and mileage
no info on if clutch/ flywheel has been done
non standard areial at front of car
add says upgraded discs and brakes, probably to vxr 345's on front
full canbus prefacelift - radio and screen could be eaisly upgraded to colour/ higer spec
add say heated seats but is missing the on/off buttons on center console
on the website it scores 4.3 out of 5 with 52 reviews you can read through
Not heated seats and not auto lights wrong light switch and mirror. With aerial at front probably ex piggy and white. Plus the est normally suffers from rear quarter glass faults on alarm system on display.
VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
TECH2WIN AND GDS2 2022 DIAGNOSTICS.
PIN RETRIEVAL FROM SOME MODULES.
Bag of poo
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
The kindergarten antics from you are worse than mine... but this is off-topic so if you want to address this further PM me.
Back on topic: I wouldn't buy that 3.2 for the simple reason getting the engine parts is equally as hard as getting parts for the 3.0v6 cdti... and when you do find them they are either used or seriously expensive. And that is even before the obvious things that aren't right. Pointed out before by others
