Results 1 to 3 of 3
Thread: Gearbox Oil M32 Manual Transmission
    Aug 2021
    Norway
    Trim : Estate
    Engine : Z19DT
    Default Gearbox Oil M32 Manual Transmission
    Hi. Going to change the oil in my gearbox (Vectra 1.9 cdti 100 hp 2008 plate). The car has driven 245 000 km, and Iíve found no record of any previous gearbox oil change.
    Living in Norway, the most recommended oil (Fuchs Titan Sintofluid 75W80) is hard to come by, and also very expensive. Are there anyone here with experience from using any other oil?
    Iíve read that the car needs GL-4 and my Haynes manual advises 75W90 viscosity. Have browsed through some alternatives, for example Castrol Transmax 75W90 and Castrol syntrans multivehicle 75W90. Also considering buying cheap fully synthetic oil from ęBiltemaĽ (Big swedish/Norwegian budget auto supply store) which is both GL-4 and GL-5 certified and has a 75W90 viscosity.
    Any recommendations?
    (Iím aware of the habit of overfilling the M32 with app. 2.5L for better effect)
    Regular Member Daywalker's Avatar
    Aug 2007
    Mitkunai k, Kaunas raj
    Vehicle : Kia Ceed
    Trim : GT line
    Engine : 1.6crdi
    Year : 2017
    If the cheaper oils meet the specs then it should be ok and you should fill to nearly 3L which most gearbox rebuilders here in the UK recommend. I used Fuch Titanfluid in mine so cant recommend any alternatives.
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    330 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Have a look in the correct section like drive train to see what others did.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  1. manual gearbox in-gear sensor?
    By 5lab in forum Engine & Drivetrain
    Last Post: 18th January 2014, 01:07
  2. Manual Transmission Fluid
    By spikeyboi33 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2013, 22:43
  3. F40 6speed manual gearbox
    By Sebastian in forum Engine & Drivetrain
    Last Post: 5th October 2012, 16:36
  4. 3.2 manual gearbox oil
    By steviemac74 in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2008, 23:13
  5. An American Dreaming about a Manual Gearbox...
    By The Doc in forum Comedy & Humour
    Last Post: 6th July 2006, 13:26
