Likes Likes:  6
Results 1 to 10 of 22
Thread: Dash light for blown bulb, but no blown bulb
    Sep 2018
    Southampton
    Vehicle : Vectra CDTi
    Trim : Exclusiv
    Engine : 1.9
    confused Dash light for blown bulb, but no blown bulb
    Hey guys,
    got a really annoying intermittent fault, happens daily. The dash warning light telling me a bulb has blown keeps going on and off. It’s linked to rear lights, as happens when I brake. I’ll get it once or twice every time I drive it.
    All bulbs are good, all work. Anyone have any ideas where to start looking for faults?
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    330 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Look in the correct troubleshooting section not this open one, lots of info but not knowing if yours is estate or hatch then hard to advise. This issue should be in only electrical but you might find it in bodywork also.
    https://www.vectra-c.com/forum/forum...k-amp-Interior
    https://www.vectra-c.com/forum/forum...luding-SatNav)
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Regular Member bibu16v's Avatar
    Oct 2021
    Timișoara
    Trim : SW Elegance II Sapphire Black
    Engine : Z18XER
    Mileage : 160k km>>
    Could be oxidised contacts in bulb socket ...it happened to me too.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    78 Post(s)
    Vehicle : Vectra C Saloon
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    it happens to everyone that owns a vectra/signum/astra/zafira/corsa (and the rest of the model line up) from the same era... always the same solution as stated above... but if a cleanup doesn't sort it out... a replacement light cluster is the only solution to sort it out (it's actually the main plate bit that holds the bulbs that needs to be replaced) and very seldom it's a wiring issue (ranging from a loose pin in the connector to wire damage)
    ps replace both bulbs to make sure it's not just a bulb going as the canbus system used on these cars is very sensitive and picks up on that too.
    Sep 2018
    Southampton
    Trim : Exclusiv
    Engine : 1.9
    Appreciate the answers guys, thanks! The annoying thing is it doesn’t say what bulb or part of the circuit is at fault, front or rear, although I’m pretty sure it’s rear. It’s there a way to test these light clusters?
    Essex
    29 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    If you look at the bottom of the page there have been a few threads like yours,have a read it might help
    Apr 2016
    Ipswich
    78 Post(s)
    Mileage : 140000
    use the good old obd2 to read it out... but you'll need either tech2 or the not talked about OP-COM.... alternatively do the pedal dance... or do as you should do and just pull out the rear light clusters bulb holders and investigate.
  8. Likes bibu16v liked this post
  9. #8
    Sep 2018
    Southampton
    Trim : Exclusiv
    Engine : 1.9
    Quote Originally Posted by northpole View Post
    I’ve got the torque app on my iPhone with OBD2 wireless scanner which is great at reading live data, but haven’t seen anything regarding lights unfortunately. OP COM / tech2 are options which I don’t have available to me.
  10. #9
    Sep 2018
    Southampton
    Trim : Exclusiv
    Engine : 1.9
  11. #10
    Apr 2022
    romania
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    You will be amazed but if you pull out your rear lights you might see that at least one of them will be blacker than the other, that one will blow up soon for sure. They don't usually blow out in the second you get the light in the dash as they still make a fair good enough contact to still bright.
    I have replaced recently a rear brake light when the check control told me a brake light was out. Guess what? It took me 4 days to swap it and it was still working but it was blacker than the other wich was a sign that the bulb will go out soon. This being said, check all your bulbs, there will be one at fault.
    The other thing to check is bad connection but that takes time while checking a bulb takes like 10 minutes.
  1. Blown Rear fog light bulb
    By Ben Chiles in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2011, 02:08
  2. bulb warning light on....but no bulbs appear blown
    By rjw in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2010, 01:18
  3. Blown bulb warning light
    By Ant S in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2009, 23:09
  4. Blown bulb indicator on dash.
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 16:20
  5. Blown bulb warning light on dash??
    By Genterz in forum Vectra C / Signum Troubleshooting
    Last Post: 9th August 2008, 11:10
