Thanks Thanks:  3
Likes Likes:  143
Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 141 to 150 of 153
Thread: signumareasa z20net
  1. #141
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    Replaced the air filter, cabin filter and spark plugs. Apparently one year is what i get out of the plugs.
  2. Likes watchman, NeilGo liked this post
  3. #142
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    LPG annual service and MOT, passed MOT with flying colors again
  4. Likes NeilGo liked this post
  5. #143
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    No much have been done, washed the car and driving it about 500km a week
  6. Likes NeilGo, Kill_Rill liked this post
  7. #144
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    The engine started to behave more and more like a sh!tbox by engine dropping the RPM under 500 (90% of the time) when it was out of gear no matter the speed but the lower the speed the more often it happened, in the end shutting off unless i was giving a tap of love to the throttle pedal multiple times untill it remembered how to idle itself. I have unplugged everything to make my job easier and now i am waiting for the sun to go away so i can put the camlocks and see if it's truly of out time or not but i suspect it is by a tooth or so, unfortunately there are no visible markings on the chain left.
  8. Likes northpole, NeilGo liked this post
  9. #145
    Regular Member NeilGo's Avatar
    Sep 2021
    Nottingham
    Trim : SRi Nav with Exterior Pack II
    Engine : 1.9 CDTi 16v
    Year : 2008
    Mileage : 179,586
    How is it all going?
  10. #146
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    Well, there is some good part and some bad part
    Good parts
    1. i have unbolted the pulley bolt wich was torqued to inifinity and beyond with a help from a friend of mine and his parkside, it started to smell a bit burned at the end after almost 10 minutes of abuse... thx monkeys
    2. i got all the replacement parts, gaskets, boot, spark plugs, oil, oil filter and a new chain tensioner(i am not willing to replace the whole kit unless it shows some wear and tear)
    The bad partS
    1. i have a right side inside cv boot wich is torned, it was a small hole but when i put my hand it started to squirt
    2. the tools haven't arrived and i really want the torque wrenches
    3. the engine is out of time, checked the timing on the 4th cilinder TDC and nothing allined properly just as a safe measure(from z22se tutorial), timing on 1st cil is bad aswell
    4. thanks to @Jon1796 gm tis is working and i was able to print the whole procedure and it doesn't look that hard
  11. Likes Jon1796, Daywalker liked this post
  12. #147
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    The drivesahft is a no saver, there was little to no grease almost left in the boot + after hammering it for 30 minutes in a big vice and not willing to come off i will just replace the whole assemble. And no, don't tell my about the cone driveshafts as i don't trust that method and i would rather replace the whole thing than bother with replacing a inner boot ever again.
    I wonder how much money will signumareasa eat again year after year
    Attachment 128170
    Attachment 128170
  13. Likes northpole liked this post
  14. #148
    Sep 2021
    Nottingham
    Year : 2008
    Mileage : 179,586
    A little more progress and great that forum members have been able to help. These are our pride and joy so money no object, right?
  15. Likes northpole, horaa liked this post
  16. #149
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    I'll give you a tip... I found that replacing the driveshafts instead of fixing the cv-joints is cheaper... because when you buy a new driveshaft you get a years warranty on the complete thing.. so if a boot goes within that period of time, send it back get a free replacement... done. it's also a lot less dirty work. just pull and replace done.
  17. #150
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    So the saga continues, i still can't drive it unfortunately and i had BIG HOPES, i mean i could but i prefer not to untill it's fixed 100% or close to
    So updates:
    1. new skf driveshaft with rubber boots instead of plastic, looks good, feels good, let's see how long it will last since it was half the price of lobro/gnk/spidan
    2. one guide rail of the timing chain setup is broken so i ordered the whole kit from febi, there were 2 prices so it might not have the sprockets, if it doesn't i'll order the one from dayco since it's a tad cheaper and the budget for is going dooooooooown faaaaaaaaaaaaaaaaaaaaaaasteeeeeeeeeeeer than i anticipated
    3. i'll retime the balancing kit aswell while i am there just as a safe measure
    4. a balljoint boot is having a metdown, apparently meyle didn't agree with my driving style through rough terrain, i'll get the boot from the old balljoints
    5. i dunno, i am tired but still not giving up, i have a feeling that this relationship with the car will make me angry enough to have a garage build at some day just for my own pleasure, also a few more tools
  18. Likes northpole liked this post
  1. signumareasa
    By horaa in forum Introduce yourself.
    Last Post: 23rd May 2022, 07:57
  2. z20net
    By richy1974 in forum Engine & Drivetrain
    Last Post: 9th September 2012, 18:49
  3. z20net
    Last Post: 14th July 2012, 19:04
  4. 2.2 vs z20net
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 22:15
  5. Anyone with a Z20NET...(2.0T)
    By n_hudson in forum Engine & Drivetrain
    Last Post: 12th March 2009, 12:35
