Results 1 to 2 of 2
Thread: Oil filter housing 3.2 vectra
    New Member Andytit's Avatar
    Feb 2022
    Kingsclere
    Vehicle : Vectra c
    Engine : 3.2 v6 petrol
    Default Oil filter housing 3.2 vectra
    I've been trying to undo my oil filter to fit new filter but when I try to take the cap off the whole housing is turning ,I've tried to put a chain ratchet to hold it but there's not enough room ,so if I keep turning it will it finally be able to remove the whole housing?
    Regular Member bibu16v's Avatar
    Oct 2021
    Timișoara
    5 Post(s)
    Trim : SW Elegance II Sapphire Black
    Engine : Z18XER
    Mileage : 170k km
    Try to pull back the whole housing and see what happens. Your situation is somehow abnormal: the housing should be kept in place by 1 hollow screw located down to the inner bottom of housing, but as far as you can rotate it I suppose screw is screwed and you should be able to remove it by pulling.
    If by any chance I could be wrong, you should be able to remove it by keeping turning on...
  1. Vectra 1.9cdti 150 Oil Filter Housing Drain Point?
    By Scotty 72 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd April 2014, 09:01
  2. Vectra 2.0 DTI Oil Filter Housing
    By Jamesx81x in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2010, 16:17
