24th April 2022, 19:09
#1
Vectra (150) 2005 1.9 cdti Wheels
Hello!
I have a 2005 SRi (facelift) and... I know, I know... it's too low! I've moved to Portugal and I've already done a lot of damage to the front skirt... lowered cars just don't work here!
Can I put 'normal' wheels on it? Is there a maximum size?
Thanks in adavance!
24th April 2022, 21:27
#2
I'm confused, is it to low? I can't even see it to agree is too low.
What are normal wheels? All Vectras/Signums have normal wheels don't they?
Is there a maximum size? Well yes they have to fit under the arches don't they?
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
25th April 2022, 10:05
#3
Originally Posted by
bryantenglish
Hello!
Thanks in adavance!
Pictures would help in this case , not always about the size of the Alloys ,Tyre size is what you are looking for .
25th April 2022, 10:34
#4
Ditch the lowered SRi suspension for standard suspension that is fitted to the Design, Elite, elegance, etc trim levels.
25th April 2022, 10:50
#5
standard sport suspension is not that low... so the car must be at least on lowering springs, but my guess is hes running coilovers.. and if that is the case even the highest setting will be lower than standard sport suspension... wheels aren't the problem the ride height is... get standard sri springs and shocks that should sort it..
northpole
Are there any coilovers, or any kind of setup that can make it higher than normal suspension (Opel Vectra estate 07' Z19DTH, IDK which trim is it)?
I would like to be able to use my car more comfortably on a bad gravel roads.
This is my first post, so hello everyone.
you can go for an airbag suspension kit and replace the lot or get the springs for the lowest spec vectra ... they aren't lowered so are up about 25mm higher on all 4 springs... but you'll need matching oem shocks as if you got oem sport shocks than the body is 15mm shorter than the non sport variants.
Post Thanks / Like - 1 Thanks, 0 Likes
Veseleilo
Bad road package.
