ignition barrel having trouble locating the hole to release barrel i have removed metal plate that is held on by three security screws only to find no hole i have original key to turn to correct position to facilitate removal the vehicle is a Vauxhall insignia 2012 with a auto box so it has a electro magnetic interlock underneath ignition switch
Vehicle : Insignia
Trim : cdti
Engine : 2.0
Thanks (Given)
Thanks (Received)
Likes (Given)
Likes (Received)
I replaced mine with total ease. My car is the 2013 auto estate and there used to be a few YouTube videos. I remember removing the plastic surrounds, finding a small Allen key and finding the tiny hole underneath the ignition. Slide the Allen key in and then push it as you fiddle the key in the barrel and it popped out very easily. I know the hole is a pain to spot but maybe lay down and look up under the ignition housing. You don't have to remove anything else as far as I remember, think it took about 20 seconds to change.
The hole is a bit of a pig to spot but you will find it. I've attached a picture that might help. I think this is the hole you are looking for.
yeah i found that it was that hole after i removed the security plate by the side of it as i expected to find another hole hidden beneath
yeah i found that it was that hole after i removed the security plate by the side of it as i expected to find another hole hidden beneath plate
Vehicle : Insignia Estate
Trim : Cloth
Engine : 2.0L Diesel
Year : 2012
Thanks (Given)
Thanks (Received)
1
Likes (Given)
2
Likes (Received)
2
An update on my fitment of a 2nd hand Ignition barrel, everything went as planned, I ordered a part on E-Bay for £40 and used the barrel and the key blades. Fitment was as mentioned in the thread by Plasma, thank you very much, and I am as happy as Larry, thx for all the help, Radio now works as it should, so does the central locking
