Thanks Thanks:  3
Thread: Heater & Fan Issues
    Regular Member purple170503's Avatar
    kent
    Vehicle : Vauxhall Vectra C - Facelift
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    Default Heater & Fan Issues
    My '06' Vec C estate is starting to show her age it seems. Hoping for a bit of advice/help please as not the greatest with cars. My heater fan won't work on either auto or the other speeds. I can't even adjust the heating directions as get no movement from the blades. Can anyone help at all please?
    13 Post(s)
    First thing to check is to see whether the fan motor still rotates or not.
    Open bonnet, remove pollen filter from under scuttle cover. Reach in and see if it will turn easily by hand.
  3. Thanks purple170503 thanked for this post
  4. #3
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    68 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    hold on what do you have in the car aircon or climatronic... if you have aircon t probably is as simple as the resistor pack needing replacing, or the blower motor is dead... in both cases it'll call for parts... if you have the climatronic i suggest you have the car readout... as the canbus will have logged an DTC (error) so you can find out what is causing the problem... and if you got the code.. post it up here and we can help you towards a solution
  5. Thanks purple170503 thanked for this post
  6. #4
    kent
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    Will have a look on Tuesday in the daylight, hoping its not gonna be more than the car is worth TBH
  7. #5
    kent
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    Quote Originally Posted by northpole View Post
    Sounds possible expensive. Will come back on Tuesday when I've had a better look. I have climatronic in mine I think, I can't remember the difference between the two. To get a reading I'm guessing I need to get it plugged into some fault diagnosis thing-a-me-bob.
  8. #6
    Apr 2016
    Ipswich
    68 Post(s)
    Mileage : 140000
    Yes you'll need to have some diagnostics done...
  9. #7
    kent
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    Sorry, is an OBD reader the thing I am after, I could probably get one from Amazon for Tuesday
  10. #8
    Apr 2016
    Ipswich
    68 Post(s)
    Mileage : 140000
    No you'll need a vauxhall specific one, the car has multiple modules that talk to one another but since vauxhall uses switching to access the different modules only specific obd2 readers can access them all.. or if you know someone that has tech2 or a universal professional obd2 reader maybe that is able to read all the modules.
    Failing that I'd suggest you look into vauxhall and obd2 software as we aren't allowed to discuss one that does the lot on the forum. It sounds like (sl)opcom
    Just leave the stuff in between the brackets off.
  11. Thanks purple170503 thanked for this post
  1. Heater issues please help!
    By Blondie Bec in forum Vectra C / Signum Troubleshooting
    Last Post: 24th December 2020, 20:31
  2. Heater motor issues
    By djlee in forum Vectra C / Signum Troubleshooting
    Last Post: 6th January 2017, 11:15
  3. Getting fed up now :( heater issues
    By Sambecky1989 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2014, 17:22
  4. heater issues not mine
    Last Post: 9th January 2013, 11:47
  5. Heater Issues
    By greenz in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 14:36
