Thanks Thanks:  3
Likes Likes:  4
Thread: Electrics go off when throttle is pressed
    Sep 2015
    pompey
    Trim : SRI
    Engine : 1.9 CDTI
    Default Electrics go off when throttle is pressed
    Morning all,
    Vectra C 1.9 Cdti 2005
    Having a strange problem, arriving home from work the other night my electrics cut out, everything, lights dash power steering, engine still l running.
    turned off and restarted, car started again fine, all electrics working again, but as soon as the throttle is pressed everything electrical went off.
    Went out to check the following morning and the battery was dead.
    Tried charging the battery overnight, seems it had, had it.
    New battery installed, car starts fine all electrics now working again, but as soon as the throttle is pressed everything electrical cuts out, the engine continues to run. some of the dash comes back on once revs settle (sometimes).
    Any ideas anyone, i'm stumped...
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    Check for any loose Earth connection (Where it goes to the Car's body) - or Positive connection, would be my suggestion.
    A tricky one, keep us posted.
    Was the original battery actually faulty?
  3. Thanks mikescort thanked for this post
  4. #3
    13 Post(s)
    Alternator putting out too much voltage maybe?
    Have you checked with a multimeter that you're only getting approx. 14 volts with the engine running? With it revving it shouldn't go above approx. 14.6 volts as the voltage should be regulated.
  5. Thanks mikescort thanked for this post
  6. #4
    Sep 2015
    pompey
    Trim : SRI
    Engine : 1.9 CDTI
    Thanks Dave and Bob, I will check the voltage at the battery tonight when the car is running, Just picked up the multimeter from work. Will also check the old battery.
    I have checked for loose connections anywhere i can but not found anything
  7. #5
    Sep 2015
    pompey
    Trim : SRI
    Engine : 1.9 CDTI
    Update:
    Went to check voltages last night, new battery is flat, I know suspecting a short somewhere,
    Will charge battery tonight, on Fri/Sat once ready I will pull all fuses and then put them back whilst watching voltage and current draw hoping to find the culprit that way
  8. Likes nikroc liked this post
  9. #6
    Essex
    28 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    Good Luck ,keep us updated .
  10. Likes mikescort, nikroc liked this post
  11. #7
    Nov 2013
    suffolk
    Trim : sri
    Engine : z18xer
    Quote Originally Posted by mikescort View Post
    Update:
    Check Glove box or Boot lights are not staying on when closed - I believe an unusual, Alternator fault, can run a battery down, too.
  12. Thanks mikescort thanked for this post
  13. #8
    Sep 2015
    pompey
    Trim : SRI
    Engine : 1.9 CDTI
    Update 2,
    Thanks everyone for your help.
    I put multimeter in series set to amps.
    drain of .5A to 2A,
    started pulling fuses, no change in drain current
    Pulled all fuses, reset everything. no drain showing on meter. 12.6V at battery
    out fuses back 1 by 1 hoping to see the drain start, nothing.
    tried the same with relays, still nothing.
    Then I remembered I hadn't checked voltage with car running as there wasn't enough power to start it last time i was looking at it.
    There is 18.4V across the battery when it's running!! (Alternators voltage regulator possibly at fault?)
    New alternator ordered
  14. #9
    Regular Member bibu16v's Avatar
    Oct 2021
    Timișoara
    Trim : SW Elegance II Sapphire Black
    Engine : Z18XER
    Mileage : 155k km
    It seems like a faulty alternator, as suggested caused by voltage regulator at fault.
    Your battery should be checked, overcharging it for a long time could damage it irreversible...but put on the new alternator and you'll find out soon, maybe you & your battery are lucky...
  15. #10
    Nov 2013
    suffolk
    Trim : sri
    Engine : z18xer
    Seems like I'm a good guesser - let us know how you get on, changing the Alternator will probably need a pit or lift.
    Had you previously tried a jump start & got the polarity wrong?
    That will mess up an Alternator.
  16. Likes soulman liked this post
  1. throttle pedal/ throttle body change
    By xantiaman1 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th May 2018, 19:11
  2. My new pressed plates
    By marc vectra sri in forum Styling
    Last Post: 19th August 2013, 09:03
  3. Question about electrics on throttle body
    By jsud2002 in forum Engine & Drivetrain
    Last Post: 8th October 2010, 19:41
  4. where to get pressed plates from?
    By Morephun in forum Styling
    Last Post: 11th February 2010, 13:44
  5. pressed number plates
    Last Post: 6th May 2009, 20:58
