12th November 2021, 10:03
#1
Rear brakes and handbrake
Hi, wondering if anyone can help? We have changed the pads, discs and handbrake cables on a vectra C.
when you apply the handbrake there is a lot of travel, when you reset the adjuster it tightens to 3 clicks which is perfect however once you press the foot brake for some reason it releases the tension?
any ideas
thanks
12th November 2021, 10:26
#2
Have you bleed the brakes? The handbrake issue sounds like rear caliper springs to me . Are your rear calipers originals? Check they are not sticking too. I had issue like that I just replaced both calipers with new springs aswell.
Sent from my SM-N960F using Tapatalk
12th November 2021, 10:48
#3
When changing pads the pedal must be pumped numerous times so piston can take up the slack BEFORE you touch handbrake.
Post Thanks / Like - 0 Thanks, 2 Likes
