Likes Likes:  3
Results 1 to 7 of 7
Thread: Electrical problems in the boot with pre-facelift Signum 2.2DTI 2003
    Oct 2019
    Riga
    Vehicle : Opel
    Trim : Signum
    Engine : 2.2 DTi
    Year : 2003
    Exclamation Electrical problems in the boot with pre-facelift Signum 2.2DTI 2003
    Hello, everyone!
    I have a few problem in the boot.. My license plate lights, 3rd brake light and the boot mechanism (electrical part) isn't working. I already measure mass to REC, which is okay, but I can't find the positive. What could be the problem? It looks like the problem could be cause by condensation, but all contacts looks alright, but not perfect of course. Any suggestions and/or experience?
    Oct 2019
    Riga
    Vehicle : Opel
    Trim : Signum
    Engine : 2.2 DTi
    Year : 2003
    Bump!
    Dec 2010
    London
    8 Post(s)
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Check loom where it goes from body into tailgate.
  4. Likes Authopsy liked this post
  5. #4
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    seems like no-one has had this exact problem before... all i can say is have you tried replacing the fuses with new ones in the rec? I had a ton of electrical gremlins that i cured by replacing all the mini fuses in all 3 fuse boxes... every single one that came out was still good but had this nasty residue on them... i decided to clean a few but when i used my multimeter they gave to much resistance.. so i decided to replace the oem ones with new ones... most problems were gone.. i still have one electrical problem but it means removing the door module in the rear.. something that can wait until it is warmer.
  6. Likes Authopsy liked this post
  7. #5
    Oct 2019
    Riga
    Vehicle : Opel
    Trim : Signum
    Engine : 2.2 DTi
    Year : 2003
    About the weather, that's true. From what I understand I just need a quick fix for the license plate lights, because the rear tailgate lights are working properly. Talking about the small fuses, I also checked all the rear ones and they also seemed okay. Maybe your suggestion could do something good. My car's MOT has ended, that's why I was thinking about a quick fix for the license plate lights. The loom seems alright, no damaged wires, the earth also seems good. I could measure the resistance, might be that it is too high. The problem started when the rear boot door opened 3 out of 5 times, until it completely stopped working. Why I think it could be a damaged or faulty REC is, because of these symptoms: the fuel cap isn't locking/opening, can be opened with using a little force to wiggle it open, the rear boot isn't opening, even tho the mechanical part is working fine, the rear license plate lights and 3rd brake light isn't working. I could check the centre and front fuses also, because I only checked the rear fuses. I'll do this and I will give an update. I also did remove the battery from the bonnet, because it had sad in the cold for approx. 3 weeks without the car being started-up.
  8. Likes northpole liked this post
  9. #6
    Oct 2019
    Riga
    Vehicle : Opel
    Trim : Signum
    Engine : 2.2 DTi
    Year : 2003
    Update:
    All I did was just remove the battery from the car for 12 hours, the ECU restarted and everything is now working. I chekced both grounds in the boot by the spare tyre and everything was okay. So anyone who might have similar problem. Try removing the battery for 12-24 hours, that might help, because all my fuses were flawless, I even cleaned the contacts with electronical contact cleaner. So God bless that the problem wasn't as bad as I first intended for it to be.
  10. #7
    Apr 2016
    Ipswich
    93 Post(s)
    Year : 2003
    Mileage : 140000
    Quote Originally Posted by Authopsy View Post
    Update:
    Typical... but i bet you the cleaning helped a bit... although I found that just erasing all the fault codes with the not talked about software, does the same a lot faster
  1. 2006 Signum Electrical problems
    By BrianNicholson in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2020, 20:51
  2. Electrical problem CIM-ECM Signum Z20NET 2003
    By turbo_larsson in forum Electrical & ICE (including SatNav)
    Last Post: 5th April 2016, 18:04
  3. For Sale: For sale my Beloved 2.2DTI signum Design 2003 140 bhp Pic heavy
    By Signum-Steve in forum Cars for sale
    Last Post: 23rd June 2012, 20:54
  4. Massive Electrical Problems with Boot Fusebox/module?
    By DTI Dave in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2011, 02:09
  5. Signum CDTi150 serious electrical problems.......... help!!
    By mr-s in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2011, 14:06
