26th October 2021, 17:04
#41
26th October 2021, 17:07
#42
Originally Posted by
Dog_Book
It would, it’s allowing air in from the wrong way and it’s also unmetered. It would also tie in with the lambs sensor fault as the ecu would be struggling to achieve the correct fuelling.
It was a fun couple of days now brakes are nice but my radiator is mess up MOT tomorrow
Sent from my SM-N960F using Tapatalk
26th October 2021, 17:15
#43
Vwdub2000
If you would've said you had sponge brakes too you would've gotten told to check the vacuum line to the servo too... would've saved you a long winded search.... but I do remember you got told check the vacuum lines also as at first we thought it was the pcv valve...
26th October 2021, 17:20
#44
northpole
My brakes weren't spongy at all they stop easily just firm. I did check and clean the valve. It was the hardline from the brake servo.
26th October 2021, 17:22
#45
To be fair, they are a ******* to spot splits like that. Its not like you can squeeze them and they open up. I bet the engine was sucking in so much air it still created a vacuum around that area so still giving the servo some draw.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
26th October 2021, 17:25
#46
I know they are hardliners and a serious pita to check.. at least you found it. Just a shame you have dented the new radiator... as long as it doesn't leak.... well erm suck it up and put the car through the MOT.
26th October 2021, 17:31
#47
Dog_Book
I was spraying electronic contact cleaner and found it.
26th October 2021, 17:34
#48
27th October 2021, 10:41
#49
northpole
If its on pipe before non return valve then it wouldn't affect the brakes.
27th October 2021, 10:44
#50
troutybrown
that is why he had no spongy brakes
