Thanks Thanks:  1
Likes Likes:  1
Thread: Vectra B 2.6 (Y26SE) fitted G cams.
    Jul 2021
    Croydon
    Trim : SRI
    Engine : 2.6
    Year : 2001
    Default Vectra B 2.6 (Y26SE) fitted G cams.
    Can anyone that has had previously had a Vectra B 2.6 tell if the car will run properly with G cams fitted? I was previously using 4XA cams and the car drove fine but I then bought a pair of G cams and replaced the A inlets with G cams and now the car is running quite rough, thought it was timing so I redid it but still no difference.
    Does the engine management system not like the G cams or is the issue something else?
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    321 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Well thats random
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  3. Likes petrolcan liked this post
  4. #3
    Regular Member petrolcan's Avatar
    Dec 2015
    Watford
    20 Post(s)
    Trim : Elegance
    Engine : 1.9 CDTI (120)
    Quote Originally Posted by Dog_Book View Post
    Well thats random
    No, it says Vectra, just not the right one.
    Okay, quite random
  5. #4
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    66 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    it's all about the the longer lift duration from the G cam giving more overlap and thus causing a "lumpy idle" but at high revs it actually makes for more BHP.... I'd say you either deal with the lumpy idle or stay with the less aggressive ones... there is a reason some of the cams are labelled for race use only... and the lumpy idle is one of them.
    up to you but if the timing is right and the car drives with more grunt you are done... or put the old ones back and enjoy the car idling normally....
  6. Thanks NeilGo thanked for this post
  7. #5
    Jul 2021
    Croydon
    Trim : SRI
    Engine : 2.6
    Year : 2001
    I was just wondering if the timing markings on cam gears need adjusting anywhere because of the longer valve open duration? I've tried asking other forums but no one seems to know, I thought maybe surely there is some owners with Vec Cs that previously owned a Vec Bs that has done this. Thanks for the info.
    https://www.migweb.co.uk/threads/4x-g-cams-in-x30xe.504706/page-2
  8. #6
    Apr 2016
    Ipswich
    66 Post(s)
    Mileage : 140000
    No you DO NOT mess with the timing it stays the same the ecu will advance or retard if needed.... put it out of spec and turn your engine into a big paperweight...
    Ps the best solution is to get your ecu remapped to account for the extra overlap...
  1. Vectra B G cams
    By Mark-R in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2014, 12:24
  2. Vectra 3.2 'G' cams?
    By L16MST in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2013, 14:59
  3. cams
    By HARRY SRI in forum Diesel Engine related
    Last Post: 17th April 2012, 15:55
  4. 3.2 Cams
    By CDXI_2003_AUS in forum Petrol Engine related
    Last Post: 3rd March 2009, 12:40
  5. Cams
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2008, 12:41
