Results 1 to 10 of 14
Thread: Headlights!
    Feb 2007
    Notts
    Default Headlights!
    i know this subject has been covered many times before - I've just fitted some Phillips Power2night dipped beam bulbs to try & cure the C**p coverage of the originals. Took it out for a drive down a dark country lane and was very disappointed. There was a slight improvemant in brightness but not on distance as some of you have stated before. Is there a way of manually adjusting the beam up slightly as it was still very dangerous doing anything over 45mph.I realise I dont want to dazzle other drivers but even another 5-10 yards of coverage would be good.
    use the white hexagon screw adjusters on the headlamps you can access from the rear of the slam panel.. they will let you move the beam, just remember not to set it too high..
    [Ex]Admin Duncan's Avatar
    There is an adjusting screw on the headlights - you could adjust them upwards to give the extra range. Just remember to put them back for an MOT.
    Damn - you beat me by seconds!!
    And again!!!!!
    Feb 2007
    Notts
    Thanks chaps I'll have a look in the morning.Is it the the one you can see on top of the headlight unit?
    yep, sure is..
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Is it possible to do this on the facelift version as well!!
    if you can access the adjusters, then yes......
  1. LHD / RHD Headlights
    By 24vElite in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2011, 19:46
  2. headlights
    By SimonL in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2010, 12:50
  3. headlights dim
    By iasha in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 16:26
  4. SRi Headlights
    By Danwells72 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 20th October 2008, 09:11
  5. Headlights
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 17:55
