looks good,
i fitted a new set of OEM Hella preface lights to mine after the originals clouded over, mainly towards the top part, and the polish /restore kit only lasted about a year before they started to dull over again
any tips on how to maintain new headlamps to prevent the issue reoccuring to new lights?
I guess an obvious one would be avoid sun light?!!
is there a uv plastic film wrap available you could apply?
Originally Posted by
test_uk
there are loads... this is just one off them
On my old astra diesel the headlights received transparent film wrapped after polishing. They are still on the car after 9 years, still clear. Just go to a tinting garage and ask them for clear tint. It shouldn't cost you that much and you won't have to bother with headlight polishing ever again, untill the HID goes bad at wich point there are kits to replace them but honestly i wouldn't do that because taking apart the headlight is a sketchy job. Better just buy new ones, hella wich is also the OEM manufacturer.
Hella isn’t the OEM manufacturer it’s Valeo.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
Then i must have looked at the wrong sticker or i wasn't really paying attention. So there isn't any hella replacement instead of valeo?
