Results 1 to 3 of 3
Thread: Rear courtesy lights not working (sort of)
    Sep 2021
    Panevėžys
    Trim : Signum
    Engine : Z19DTH
    Default Rear courtesy lights not working (sort of)
    Hello, I recently bought a 2007 Signum, and I noticed that the rear courtesy lights work when you press the button for them, but they don't when the doors are opened. Tapping on the plastic part makes them light up (or stop working from the doors) even when the doors are opened. What could be the issue here?
    Regular Member NeilGo's Avatar
    Sep 2021
    Nottingham
    Trim : SRi Nav with Exterior Pack II
    Engine : 1.9 CDTi 16v
    Year : 2008
    Mileage : 174,000
    Hi there. There have been some similar discussion threads in the past - here's one of them - might be helpful/point you in the right direction
    https://www.vectra-c.com/forum/showt...e-on-with-door
    Only other thing I can think of is disconnect battery and reconnect to see if that 'resets'. Apart from that, the other thing is to wait for one of the technical gurus here to help you solve the problem.
    Hope you can get it fixed.
    Neil
    Regular Member bibu16v's Avatar
    Oct 2021
    Timișoara
    Vehicle : Vectra C
    Trim : SW Elegance II Sapphire Black
    Engine : Z18XER
    Mileage : 170k km
    It's possible to have some bad/losen contact on that lamp...removing the lamp and its connector may give you an idea about the problem. Cleaning the connector with contact spray would be also recommended.
  1. 08 Vectra C - Interior front/rear lights not working
    By shuz in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2019, 09:29
  2. Rear Lights not working
    By acsmith1961 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2018, 09:58
  3. No working rear lights or tailgate
    By TonyP2020 in forum Electrical & ICE (including SatNav)
    Last Post: 8th August 2016, 21:56
  4. Rear Left Lights Not Working
    By sammy91 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2013, 11:52
  5. Various Rear Lights Not Working
    By TRICKYRICH in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:20
