Results 1 to 10 of 13
Thread: oil leak help needed
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Default oil leak help needed
    i went to the dealers last week with a list of niggles including an oil leak that was spotted were the gear box / engine bolt together, i was told to keep an eye on it...
    well got it up on the ramp again today and i was confronted with what appears to be fresh oil dripping down of the exhaust bracket onto the belly pan, the engine oil level is ok but dont know how to check the gear box level.
    i called the dealers straight away and they said to bring it in on tues so they can have another look at it, i took some pics but they are not the best in the hope that the ones in the know can put my mind at rest about wether i should carry on driving it till tues or not, the gear change action is the same as it was when we brought the car so i'm getting a little tetchy about where it is coming from.
    hope someone can help and thanks in advance.
    Midlands Mod Shop - NFFC.
    hmm, it also seems to be in line with the oil filter housing as well.. if it is coming out between the engine and gearbox, then it'll be the rear crankshaft oil seal..quite a large job..
    is it safe to drive?.. well, if there's oil in the sump then yes, but avoid long runs..
    have they left the belly pan off??.. can you raise it and see if it's engine oil ( which it looks like) or reddish gearbox oil?..
    Trim : Get a
    sorry for the delay in reply m8 just dropped swmbo of in town for a hen night....
    anyway the oil is not red so must be from the engine and yes it does appear to come from the oil filter housing aswell, is this a common fault or not and how long will it take to do cos a courtesy car not avv till 23rd of this month, dont want much info do i mate ?
    i'd first off take a look at the seal on the filter cap. it's just an 'o' ring..and it it's leaking past the seal, then it'll drop down onto the exhaust, just like in the 1st photo....i'd try a new seal there..
    if it is the rear oil seal, then i'd suspect excess crankcase pressure as that normally pops the rear oilseal.. either that or a stcuk oil pressure releif valve in the oil pump..
    if it's under warranty, push for a quicker check-in, and a rental car FOC from VX customer services..
    Trim : Get a
    cheers m8 will give them a call tomorrow and tell them i'm not happy with the courtesy car time and see what happens, you never know it might make them pull there finger out ?
    thanks for the advice and help mate will post up the final analisis when its all sorted out.
    yep, do that Rich....
    Regular Member benny's Avatar
    Feb 2006
    dudley
    have you had a oil and filter change in the last few weeks? ......
    Trim : Get a
    was serviced 3 weeks ago by an indipendant vx service centre and it was then the leak was spotted dude, when i took it to the dealers they told me keep an eye on it...
    Feb 2006
    dudley
    the stains on the pipe look like the residue from the oil filter drain ..they have a yellow cap on them you wind the oil filter out so far and it drains into a small pipe fitting that you put a hose onto and into the drainer you then change the filter and replace the 2 oil seals .....if they aint removed the yellow cap and used a drain pipe (lots a people dont know what it is there for) the oil that was traped/ drained out has made the stains on the pipe (nowt to worry about)..the oil leak from the box / engine area does look like the rear crank main wich has been seen on these engines before if it keeps leaking they will need to remove the box and have a look at the seal ....dont leave it too long as it may contaminate your clutch plate .......
    Trim : Get a
    cheers mate, it was spotted before the oil an filter was changed so im going with the idea of the oil seal..and getting on to vx tomorrow about it
  1. Oil Leak+Clutch+DMF - Advice Needed Please
    By bigade1 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 20:54
  2. Help needed with leak on signum :( (with pics)
    By Shogun in forum Bodywork & Interior
    Last Post: 8th November 2011, 14:26
  3. Help needed Vectra oil leak
    By tunnafish in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2011, 09:32
  4. oil leak help needed
    By b3kaw in forum Engine & Drivetrain
    Last Post: 15th March 2010, 20:55
  5. help needed on blowers and leak....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 15:02
