Hi guys was just reading a post on here about the rattle on cold. Since I've owned my insignia it does this rattle but only when cold. Has anybody remedied this or is it can gear change the only solution? Many thanks.
Been trying to find the edit function but no joy. It's the 1.8 vvt engine and will the rattle on start up only go after cam gear has been replaced. Or is there a solution? Many thanks
If you wait a few seconds after turning on the ignition, BEFORE starting the engine (Put seat belt on perhaps) they seem less liable to do this rattle.
My friend said it's the oil not getting there but when engine is warm no rattle. Read a few posts on here about removing the gauze from filters. But the posts are from like 2010
why do you ask? (no need to answer it is a rhetorical question) it isn't hard to look on ebay at all, just type in your car details on ebay and look for it yourself, you know what the part is called so you should be able to find it quick enough... and if you don't trust eBay well you can do the same on Amazon... both cater for car parts.
I have looked but never seen the part it showed me. On my car.
If the engine is the same as the vectra one or very similar just look at the plethora of threads regarding the 1.8. That’s what I’d do.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
