Thanks Thanks:  2
Thread: Boot won't open
    Jul 2021
    South Wales
    Trim : Life
    Engine : 1.8
    Default Boot won't open
    Today I closed the boot on my Vectra hatchback as normal, then when I tried to open it a short while later I can hear the motor whirring but the boot remains locked. I've pressed the boot unlock button on the key remote as usual.
    Also, when I start the car I'm getting the boot open warning on the dash and the associated warning chime.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    65 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Well it would be nice if you finally take the time to introduce yourself and put a picture up of the car (you've been around long enough)
    open the boot with the key remove the plastic panel and you'll have access to the complete mechanism... you'll soon find out why it is acting up. but usually it is corrosion.
    Jul 2021
    South Wales
    Trim : Life
    Engine : 1.8
    Sorry mate, just hoping for some advice.
    There doesn't seem to be anywhere on the boot lid to insert a key - there is just a button which triggers an electrical mechanism. I can hear the mechanism whirring but it's not opening.
    I can fold the rear seats and get some access to the boot that way but I have no way of opening the boot.
    Apr 2016
    Ipswich
    65 Post(s)
    Mileage : 140000
    if you've got number 5 on the picture below you'll have to remove the panel from the boot ,it can be done but you might damage it ..
  5. Thanks msr501 thanked for this post
  6. #5
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    16 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2022 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
  7. Thanks msr501 thanked for this post
  8. #6
    Apr 2016
    Ipswich
    65 Post(s)
    Mileage : 140000
    that is if they put a panel on with the blanked hole... mine doesn't have it, but i have the key as a last resort and a pair of pliers, i actually oil mine 4 times a year so it doesn't seize and even than i have to use pliers or risk breaking the key in the lock.
  9. #7
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    318 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Let me do a Southpole and talk before checking, I thought this information was held in the owners manual? If so it makes for lots of stupid people commenting in the video
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  10. #8
    Apr 2016
    Ipswich
    65 Post(s)
    Mileage : 140000
    Quote Originally Posted by Dog_Book View Post
    someone asking for some abuse over whatsapp???
    i clearly checked see the blowout picture and the 2 different locks in the picture... also pointed out that mine does not have a access hole in the plastic cover, possibly because of the fact that mine can be operated with the key (and a pair of pliers or you'll break the darn key and no it is not seized it just needs quite the some leverage to actually turn)
  11. #9
    Jul 2021
    South Wales
    Trim : Life
    Engine : 1.8
    Thanks to all for your help - mine had the little plug on the inside of the hatch like the Zafira in the video - I was able to prod a screwdriver in there to get the boot open again.
    Good thing Vauxhall were sensible enough to include this, otherwise this could have been a world of bother.
    After I closed it again it opened normally using the button for the first time but the second time it got stuck again
    I guess one day I'll need to get the panel off and see what's going on
  12. #10
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    was a common issue on these where they would fail like that. I managed to get a new one replaced under warranty and had been fine ever since
  1. Replies: 4
    Last Post: 25th July 2013, 16:21
  2. HELP!!! Boot won't open
    By Critch in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd September 2011, 22:49
  3. boot when open
    By slugo in forum Bodywork & Interior
    Last Post: 6th April 2011, 18:44
  4. Can't get boot to open
    By melvin in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2011, 14:57
  5. boot will not open!!
    By p.bamforth in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2010, 13:00
