Likes Likes:  2
Thread: P0100-52 and P0400-11 faults solved! (on Z30DT)
    Regular Member jannie's Avatar
    Sep 2017
    Western Cape
    Vehicle : Vectra-C 3.0 Elite Estate
    Trim : Leather seats
    Engine : CTDI 3L (Z30DT)
    Mileage : 117000
    Red face P0100-52 and P0400-11 faults solved! (on Z30DT)
    I had these faults for 18 months because the garage could not find the problem.
    P0100 (52) not present Mass or volume Air Flow Sensor Circuit - Malfunction
    P0400 (11) present Exhaust Gas Recirculation Flow Excessive
    The car was always in limp mode and ran very unevenly.
    The result was that the car stopped running due to a blocked DPF and the swirl flaps often got stuck open and closed - all due to the wrong fuel mixture.
    I finally decided to run tests on the EGR. 12VDC across pin 4 (Red/Yellow) (+ve) and pin 6 (Pink/Yellow). The valve clicked in and out. Then applied 5VDC across pin 1 (+ve)(Red) and pin 2 (Black/Red) and measured the sensor signal on pin 3 (Orange/DarkGreen) while varying the solenoid signal from 0 to 12V. Could not detect anything. But on OP-COM the EGR Output test showed a signal so I was relatively happy.
    After checking for leaks in the pipes, I then decided that the problem may be with the MAF, which I had replaced one year before the faults appeared. The OPCOM MAF signal was erratic, confirming a problem. Fortunately my garage had a second-hand Volvo MAF insert which is also a Bosch F00C 2G2 061 (and the same MAF seems to be used for Mercedes and Audi - look around for a cheaper option than the stock Vauxhall part - you only need the insert).
    All problems instantly disappeared after replacement and a whole 200ml can of Wynn's Carbon Buster (Compression Stabilizer) sprayed into the inlet to get rid of the stuck swirl flap faults. Finally. Yeay.
  2. Likes Dog_Book, nikroc liked this post
  3. #2
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    Thanks for sharing ,still a new member ? even tho you joined in 2017 ,have you ever posted up a picture of your car ??
    welcome by the way
  4. #3
    Sep 2017
    Western Cape
    Mileage : 117000
    Quote Originally Posted by soulman View Post
    welcome by the way
    I have posted quite a few times (mostly questions). No photo submitted but I have a stock standard blue 3.0l Estate. Should I post a pic somewhere?
    BTW, I lived in Romford for 3 years before returning to South Africa, with my Vectra-C in tow, because I couldn't get any decent money for it. The only problem here is spares and agents - we have neither. GM left the country recently and also the Vectra-C was never sold here.
  5. #4
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    Oh yes very important to post pictures ,did you ever introduce yourself ? there is a forum section for that . Romford just up the road from me in Aveley .
  1. Y20DTH & p0400-09 + p0400-05
    By ajcollins2 in forum Engine & Drivetrain
    Last Post: 23rd September 2016, 19:53
  2. P0100 AND P0400 - Limp Home Mode - Vectra C 2003 DTI 2.0 Elite - Y20DTH 168K Man
    By tk007b in forum Vectra C / Signum Troubleshooting
    Last Post: 29th August 2016, 00:07
  3. P0100
    By jensie in forum Engine & Drivetrain
    Last Post: 4th March 2016, 19:17
  4. p0100-21 and p0100-08 discussion...
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2013, 01:31
  5. Replies: 2
    Last Post: 11th July 2013, 14:21
https:www.vectra-c.comforumshowthread.php237044-P0100-52-and-P0400-11-faults-solved!-(on-Z30DT)&p=2534294
