Likes Likes:  2
Results 1 to 10 of 15
Thread: Squeal on start up and stays on.
    Mar 2011
    berkshire
    Vehicle : Vauxhall vectra 1.9cdti 8v 120bhp
    Trim : Breeze
    Engine : 1.9cdti
    Mileage : 166,000
    Default Squeal on start up and stays on.
    Vectra c 1.9cdti 120 8v 2005.
    Car has suddenly started screeching on start up, its screeching on/off even on idle. when driving its hardly there until im slowing down and turn to park.
    All videos on youtube pointing to belt with similar noise.
    Anyone who has had this issue please advise.
    Many thanks.
    Regular Member petrolcan's Avatar
    Dec 2015
    Watford
    20 Post(s)
    Trim : Elegance
    Engine : 1.9 CDTI (120)
    I'd concur with the youtube videos, it's a belt with a similar noise.
    Mar 2011
    berkshire
    Trim : Breeze
    Engine : 1.9cdti
    Mileage : 166,000
    Shall i get belt kit?
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    318 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Yeah I did.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    65 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Quote Originally Posted by jingerman View Post
    no it will go away by itself, after all cars don't need maintenance
    of course replace the belt and while you are getting parts get the tensioner for it too....
  6. Likes soulman liked this post
  7. #6
    Mar 2011
    berkshire
    Trim : Breeze
    Engine : 1.9cdti
    Mileage : 166,000
    Today battery light came on dash and squeaking vanished. Might be alternator Thats been making noise?
  8. #7
    Mar 2011
    berkshire
    Trim : Breeze
    Engine : 1.9cdti
    Mileage : 166,000
    Or could it still be belt causing all these issues?
  9. #8
    Full Member
    Jul 2018
    BIRMINGHAM
    Trim : Life
    Engine : Z19DT
    Year : 07
    The squeaking is due to the belt slipping. As it's slipping, it's not turning the alternator as much as it should be hence the battery light.
    Fix the belt before you go changing the alternator.
  10. #9
    Mar 2011
    berkshire
    Trim : Breeze
    Engine : 1.9cdti
    Mileage : 166,000
    Took car to mechanics, light came on. Mechanic used multi-meter and said Alternator aint charging. Within minutes lost steering etc etc. Left with mechanic.
    Quoted Alternator £150 & £120 labour.
  11. #10
    Full Member
    Jul 2018
    BIRMINGHAM
    Trim : Life
    Engine : Z19DT
    Year : 07
    I'm going to channel my inner Dog_Book:
    What's the point in asking for advice if you're not going to follow it? Other people have told you it's the belt and/or tensioner (you even said that yourself) then you've found another symptom of the faulty belt and I've explained why it's a symptom, not the cause.
    Now you're going to be out £270 with a battery light still on because your new alternator isn't getting driven by the faulty belt.
    If you do decide to continue, FYI you can get your existing alternator refurbed for £80ish and have it off and back on yourself with 2 hours work, and that's when you don't know what you're doing.
  12. Likes Dog_Book liked this post
  1. Z19dth squeal on cold and warm start up
    By miniator in forum Engine & Drivetrain
    Last Post: 21st July 2017, 11:08
  2. Autolight stays on
    By lynx84 in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2015, 21:55
  3. Replies: 0
    Last Post: 8th October 2012, 09:36
  4. start up squeal noise 1.9 cdti 120
    By firebeast in forum Engine & Drivetrain
    Last Post: 20th September 2012, 10:46
  5. BC Range stays the same after top up??
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2011, 17:36
