Thanks Thanks:  1
Likes Likes:  4
Thread: New Battery problems
    Full Member Johnsdutton's Avatar
    East Kilbride
    Engine : 3.2 v6
    Mileage : 140,000
    Default New Battery problems
    I changed my battery yesterday, (old one would not hold a charge, it was almost 10 years old)
    My problem now is that I can't use the radio after the battery swap. everything else works. Doors even auto lock 30 seconds after key removal, which it has never done in all the time i have had the car, 13 years. Windows will close with the key and remote, but not automatically.
    I have the radio code but i don't know how to access the screen to enter it.
    Radio is Phillips CCR2006.
    Does anyone have any suggestions?
    3.2 v6 Signum and loving it 😁
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    65 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    When you turn the contact on, the screen should switch to asking for the code, that is when you put it in. You use the number pad on the radio to put it in.
    When done press the middle of the volume button.
    That is if the radio is turned on... if it is off you won't be able to put the code on until it is turned on, and the code input is displayed on the screen. (Tid, cid, or gid)
    East Kilbride
    Engine : 3.2 v6
    Mileage : 140,000
    Unfortunately i am not getting the option of entering the radio code. The screen will only let me check range trip consumption etc.
    On the top row with radio switched on it says,
    first box 26.5C ,
    second box PANEL,
    third box 19:43
    With radio switched off it says
    top row, PANEL
    second row first box,26.5C, second box19:43
    third row Range201miles
    fourth row is temp and fan speeds.
    i am trying to upload pictures, but for some reason my phone and pc are not talking to one another.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 140,000
    Quote Originally Posted by Johnsdutton View Post
    first box 26.5C ,
    second box PANEL,
    third box 19:43
    top row, PANEL
    I think.i have got the photos now.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 140,000
    Full Member
    Jun 2016
    Blaenau Ffestiniog
    Engine : 2.2 direct
    If i remember correctly... With the ignition on, turn the radio off. Then press and hold AS. While holding AS, turn the radio on. Keep holding AS and you should hear a beep and you should then be able to input the code
  7. Thanks Johnsdutton thanked for this post
    Likes Johnsdutton, petrolcan liked this post
  8. #7
    East Kilbride
    Engine : 3.2 v6
    Mileage : 140,000
    Quote Originally Posted by Pinkywafer View Post
    Thanks Pinkywafer.
    I tried it and it worked.
  9. Likes Pinkywafer liked this post
  10. #8
    13 Post(s)
    Here's a PDF document for the CCR2006, should you need it for future reference, or any other features you're not aware of.
    http://www.opel-niedersachsen.de/med...r2006_2002.pdf
  11. Likes petrolcan liked this post
  12. #9
    East Kilbride
    Engine : 3.2 v6
    Mileage : 140,000
    Thanks Big Dave.
    That will come in useful.
  1. Battery light/ alternator problems possible
    By Hoggle in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2016, 23:33
  2. Battery problems
    By jamiedvvt in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2014, 10:20
  3. Battery Problems
    By danny1992 in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2011, 16:51
  4. good old battery problems again
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 16:18
  5. Battery problems
    By jaxouk in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2008, 22:05
