Results 1 to 3 of 3
Thread: Vectra C 2008 1.9cdti Power Steering problem
    Nov 2015
    Reading
    Trim : 5 Door 1.9 CDTi
    Engine : 1.9 Diesel
    Default Vectra C 2008 1.9cdti Power Steering problem
    I have a Vectra C 1.9cdti @ 118K miles. The power steering became heavy and the steering fault light came on.
    I have replaced the EHPS power steering unit with a 2nd hand unit. I have followed the bleeding procedure and the fault light has gone out, but the steering is still heavy.
    Alternator output 14.3V on idle, 13.9V with lights on. Fuse F9 is OK. Not sure what to do next, any suggestions greatly appreciated.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Replace the fuse regardless of ot being fine.. when I got my car I had numerous of faults... one being a constant interior fuse popping... I pulled the fuse no break or anything... but put it on a multimeter and it gave way to much resistance...
    So I replaced all the fuses in my car... and until today I have no more weird faults...
    So just make sure it's not just the fuse being a problem and replace it. If it starts working you've found the problem.if not well not to much money down the drain
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    That’s an unusual introduction since being registered 6 years ago
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  1. 2008 vectra C 1.9cdti 120bhp Gearbox problem
    By macdanger in forum Engine & Drivetrain
    Last Post: 11th September 2019, 11:40
  2. 1.9cdti 150bhp 55 plate vectra power steering stopped operating
    By Whiteknight841 in forum Engine & Drivetrain
    Last Post: 13th June 2013, 14:21
  3. Vectra C 52 Plate Power Steering Problem
    By Nath79 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th February 2011, 14:28
