could anyone tell the two pin numbers for the outside temp is plug into the blue cable and the blue/white cable thanks
Hi could you advise as to which head unit / car you are talking about , things are a bit quiet on here due to the nice weather ,so hopefully someone will help when they log in .
its the cd70 navi just wanted to know the outside temp pin numbers where in just to make sure got the right way round which i dont think i have thanks
@plasma is probably the guy you need
what year vehicle? as preface and facelift both have different pin locations
its a 2005 version
just put in the complete details of your car mate, as the 2005 can be both half-canbus or full canbus:
year/model/trim/engine/radio/
note: a preface has a bigger bonnet that folds down to the bumper that has the grill integrated, where the facelift has a grill going up to the bonnet.
this makes no sense, his car is listed as a corsa se 1.4T 2016, and asking a question about wiring in the insignia section for the temperature sensor which would be on the IPC plug on one of these, but says he has a CD70 and now its a 2005 in which case vectra/signum dont have temperature sensor wiring going to the centre display.
someone is on a windup
That because I am not installation it in a Corsa I'm trying to get it to work on combo van that's why I know that some off pins have to be swap around to make things work
