Likes Likes:  1
Thread: Rear pads.
    Dec 2017
    northern Ireland
    Vehicle : vectra
    Trim : sri
    Engine : 2.0t
    Default Rear pads.
    I can’t seem to find rear pads that sit in flush with my discs. They sit up higher than the outside edge of the disc. Discs are 278mm with new calipers. Anyone had this before? Cheers
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    15 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Probably because the carrier is for 292mm discs.
    plus as I remember they where vented on my old 2.0t.
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2021 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
  3. Likes Dog_Book liked this post
  4. #3
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    315 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Correct cabbage boy Jon, a 2.0t uses 292 vented on the rear and you can see in the photo there is a massive gap from the disc outer to the carrier. So if the carriers are original that shows the discs should be 292 and also the calipers should be the wider versions for the vented discs.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  5. #4
    Dec 2017
    northern Ireland
    Vehicle : vectra
    Trim : sri
    Engine : 2.0t
    Ah right that explains it. A previous owner has obviously put 278 discs and calipers on at one time then! Thanks for the quick response guys. Funny thing is I actually have a pair of vented discs but I thought they wouldn’t fit the carriers. Looks like I just need the wider calipers now
  1. New rear pads
    By Usselbird in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2013, 23:00
  2. rear pads.
    By marc vectra sri in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2013, 20:09
  3. which rear pads for a 3.2?
    By andyxedos in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 19:05
  4. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
  5. Have I got the right rear pads?
    By bigun in forum Suspension, Wheels & Brakes
    Last Post: 17th July 2007, 13:09
