Thread: any pointers
    beds
    Default any pointers
    looking for pointers signum 1.9cdti 150 bhp 2007 won`t start
    no fault codes
    right drove 10 miles from work stopped to pick something up from screwfix had terrible job to start requiring a boost pack sound slightly noisy drove rest of way home vehicle drove okay no misfires but sounded as thou starter may have had stuck in switched engine off tried to start cranked over and over wouldn`t start so have done following
    change fuel filter checked low pressure pump flow to filter all good
    checked fuses and relays seem ok
    changed crankshaft sensor
    changed fuel rail regulator & changed fuel pump along with metering valve even thou pressure is okay in rail
    engine will run on brake cleaner sprayed into air filter box so assume timing is ok
    just no fuel being injected by injectors
    is there a correlation between crankshaft sensor and camshaft sensor ?
    is there known wiring issues somewhere ?
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    313 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    This is the area you want to be looking in https://www.vectra-c.com/forum/forum...amp-Drivetrain
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    beds
    been through that nothing close to problem i have im afraid
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    15 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    1 Q what you using to read faults.
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2021 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
    beds
    ive used a hand held sealey one just does engine codes
    and a Autel maxicomm that does everything on car
  1. Aircon pointers
    By carvaletingpro in forum Vectra C / Signum Troubleshooting
    Last Post: 16th July 2013, 21:12
  2. need some pointers
    Last Post: 10th June 2010, 22:44
  3. lowering-views/pointers/help
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2008, 23:58
  4. how your mouse pointers actually work!
    By eug4611 in forum Comedy & Humour
    Last Post: 8th August 2007, 10:25
  5. need a few pointers
    By m20_swe in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2006, 23:14
