Thanks Thanks:  2
Likes Likes:  2
Thread: Where to buy Upgraded high pressure fuel pump
    May 2021
    Finland
    Vehicle : Vectra c 2.2 2006
    Trim : Opc
    Engine : 2200
    Default Where to buy Upgraded high pressure fuel pump
    Hey everyone,
    I have been looking for upgraded high pressure fuel pump for couple of weeks. I made basket and ordered. However, F5r doesn't reply anymore. They have to approve order and send me bank details for payment I guess?. Do you guys know any other stock?
    Dec 2010
    London
    5 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    F5r only ones i.ve seen.
    You can always buy seals and repair your own but the same fault will reoccur due to the ethanol in the fuel.
    With the F5r Bosch pump it uses steel pistons instead of rubber diaphragms so it eradicates the ethanol problem.
  3. Thanks Suomi123 thanked for this post
    Likes Suomi123 liked this post
  4. #3
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    61 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    this is the problem since they have advertised it and are the only ones actually offering the F5R bosh pump as a replacement... they also put on the website that they are out of stock and have a break for a while so won't be back to doing business for a while... but you can always contact any diesel specialist and ask for that pump... problem is the lot isn't online with the part numbers... they source it directly from Bosh so a diesel specialist might be able to source one for you.
  5. Thanks Suomi123 thanked for this post
  6. #4
    May 2021
    Finland
    Trim : Opc
    Engine : 2200
    Thank you guys. Hopefully they contacted back. Right now waiting time is around 2 weeks.
  1. High Pressure Fuel Pump
    By trevteah in forum Engine & Drivetrain
    Last Post: 9th October 2010, 19:09
  2. air con and high pressure fuel pump
    By dayna1501 in forum Introduce yourself.
    Last Post: 23rd June 2009, 18:52
  3. High pressure fuel pump
    By dougiemc in forum Engine & Drivetrain
    Last Post: 3rd May 2009, 21:32
  4. High Pressure Fuel Pump
    By nesbigr0 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 17:08
