Likes Likes:  2
Thread: Electric front seats
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    15 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Default Electric front seats
    Right electric front seats first Q1. Is if you take seat out it should sit level on floor 2 pins at rear and front slots all touch.
    As mine dont seams one rail is at a different angle to the other.
    I had bolster repaired guessing that was when it got out of shape.
    Q2. Is there a manual adjustment on motors to readjust.
    ​​​VECTRA VXRs BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2021 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    61 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    When I replaced my seats for leather ones I noticed that one of them had the same problem.... although those are manual...
    A1 yeah it should be exactly the same.
    A2 flip the seat upside down and you can just move it back into position if you turn the aluminium pipe as that is the position unlock part of the system.
    Sep 2015
    Norwich
    15 Post(s)
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    While going through it in my head last night remembered there was a bolt loose on the end off that thread pipe.
    I’ll take a pic, easier, later.
    Sep 2015
    Norwich
    15 Post(s)
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Took bar off and it went straight to max height so adjusted bar to match still slightly out but better than it was, also drilled out worn rivet rear left so I can replace with spacer/collar as plastic washer had worn.
    3AF3B79D-0254-4DB7-B311-86E6C0D005D7.jpgF299999A-D95E-477B-B522-FD96F48F97AE.jpg0BA17189-20C9-4DCE-82DD-5DFF4C6D62D7.jpg
  5. Likes northpole liked this post
  6. #5
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    313 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    what you dicking around with now?
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  7. #6
    Sep 2015
    Norwich
    15 Post(s)
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Got a really annoying a hole that keeps me up at night, and seat wobbles
  8. #7
    Oct 2013
    Derby
    313 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by Jon1796 View Post
  9. Likes Jon1796 liked this post
  1. Heated front seats/ electric rear windows
    By Anth1718 in forum Bodywork & Interior
    Last Post: 9th December 2020, 10:47
  2. Ford Granada front electric leather seats
    By Andy17899 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 2nd October 2008, 13:29
  3. Electric Front Seats
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 18:03
  4. Replies: 8
    Last Post: 27th January 2007, 22:02
