Electric front seats
Right electric front seats first Q1. Is if you take seat out it should sit level on floor 2 pins at rear and front slots all touch.
As mine don’t seams one rail is at a different angle to the other.
I had bolster repaired guessing that was when it got out of shape.
Q2. Is there a manual adjustment on motors to readjust.
When I replaced my seats for leather ones I noticed that one of them had the same problem.... although those are manual...
A1 yeah it should be exactly the same.
A2 flip the seat upside down and you can just move it back into position if you turn the aluminium pipe as that is the position unlock part of the system.
While going through it in my head last night remembered there was a bolt loose on the end off that thread pipe.
I’ll take a pic, easier, later.
Took bar off and it went straight to max height so adjusted bar to match still slightly out but better than it was, also drilled out worn rivet rear left so I can replace with spacer/collar as plastic washer had worn.
3AF3B79D-0254-4DB7-B311-86E6C0D005D7.jpgF299999A-D95E-477B-B522-FD96F48F97AE.jpg0BA17189-20C9-4DCE-82DD-5DFF4C6D62D7.jpg
what you dicking around with now?
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
Post Thanks / Like - 0 Thanks, 3 Likes
12th June 2021, 17:43
#10
I’m gonna come over there and eat you out house and home, fat boy
also as a precaution he’s making up a slightly different shoulder washer I believe their called.
rough sketch, but I know what I mean.
and the part that had failed.
