Likes Likes:  1
Thread: Squeak from belt side at low RPM
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Squeak from belt side at low RPM
    Ive got the really annoying chirping/ squeaking sound coming from the belt side of the engine but only does it when im accelerating in low revs and the engine labours. It does between gear changes until the revs get high enough that it stops
    I changed the belt tensioner today for a new GM one which has got rid of 85% of the noise but it hasnt cured it fully. Im able to pull away now without any noise but im still getting some noise if the revs are too low
    Does anybody else know what it might be?
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Did you not change the belt? It is the most likely cause of that noise... I recently replaced mine because I had the same going on (although my engine is a 2.0 dti) and when I took the old belt of and compared it to the new one it had stretched a whole cm. So I could literally put the old one around the new one.
    Swapped it over noise is gone.
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Quote Originally Posted by northpole View Post
    Thats probably it
    As i was fitting the new tensioner i was thinking maybe i should of stuck a new belt on while im at it :-(
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    Lucky for you the belts are cheap... just grab one already and replace it.
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    just ordered a SKF one online as ECP and GSF off the shelf are crappy ones
  6. Likes northpole liked this post
  1. squeak squeak squeak squeak drive belt
    By martygibson1888 in forum Engine & Drivetrain
    Last Post: 8th February 2013, 17:20
  2. brake squeak squeak not a mouse!
    By paul.sessions in forum Handling & Braking
    Last Post: 22nd September 2010, 21:40
  3. Auxiliary belt squeak!
    By Croxley in forum Engine & Drivetrain
    Last Post: 1st June 2010, 21:06
  4. Driver Side Belt Buckle
    By ZC_74 in forum Bodywork & Interior
    Last Post: 21st March 2008, 10:00
  5. Small squeak from engine belt - cdti 120
    By spartan80 in forum Engine & Drivetrain
    Last Post: 26th October 2007, 07:50
