Likes Likes:  9
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Z18XER inlet timing fault
  1. #21
    Oct 2013
    Derby
    315 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by Jon1796 View Post
    im gonna come and see you one night sleep with one eye open fat boy
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  2. Likes Jon1796, nikroc liked this post
  3. #22
    Regular Member JagRigger's Avatar
    Norfolk
    5 Post(s)
    Trim : Design
    Engine : 1.8 VVT
    Mileage : ... 244K!
    OK - update. Last week did about 1200 miles. Generally the car drove OK with no fault light, but was still logging P0011-061 in the background, which I got by daily checking on the laptop. However, if I stopped the car once warm and set off shortly after it put the light on until I cleared it ( sometimes a few times too ) It's got to be something affected by heat soak I think, so in for a penny...... I fitted a replacement full engine loom yesterday. Once I get a replacement throttle cooling pipe and can test it, I'll let you know ( brittle little things those pipes - broke both but only had a spare for the one from the thermostat )
  4. Likes northpole, Dog_Book, Jon1796 liked this post
  5. #23
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    15 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Untitled.jpgHave you looked on tis for there remedies for this..
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2021 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
  6. #24
    Norfolk
    5 Post(s)
    Trim : Design
    Engine : 1.8 VVT
    Mileage : ... 244K!
    Right - still doing it, but now throwing low voltage at that solenoid.
    Jon - my TIS is so old it runs on steam. Is that suggesting a possible ECU fault ? ( if so I know just the man down Sprowston Road )
  7. #25
    Sep 2015
    Norwich
    15 Post(s)
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Mr Cjcars
    i’ll have a look
  8. #26
    Sep 2015
    Norwich
    15 Post(s)
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    check uec fuse fe14 10 amp that feeds it.
    think you need to go through wiring from uec through to ecu.
    could be bad wiring uec or ecu.
  9. #27
    Sep 2015
    Norwich
    15 Post(s)
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Bring her over we could go through tis if you got time.
  10. #28
    Dec 2010
    London
    5 Post(s)
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    That's for camshaft sensor his code was for vvt solenoid i think.
  11. #29
    Dec 2010
    London
    5 Post(s)
    Trim : Premium SE
    As above clean fuse 14.
    Pin no.3 on ecu is yellow/violet that goes to inlet vvt solenoid.
    Also check for corrosion but imagine you already done this when loom was changed.
  12. #30
    Dec 2010
    London
    5 Post(s)
    Trim : Premium SE
    Fuse 14 also feeds Oxygen sensors.
  1. Z18XER timing belt balls-up: HELP!!!
    By jaa500 in forum Engine & Drivetrain
    Last Post: 23rd April 2018, 14:47
  2. Multiple Fault codes Z18XER
    By Rich8 in forum Engine & Drivetrain
    Last Post: 21st January 2015, 20:42
  3. timing belt changed with inlet?
    By hairy31 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2011, 13:20
