Likes Likes:  9
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Z18XER inlet timing fault
    Regular Member JagRigger's Avatar
    Norfolk
    5 Post(s)
    Engine : 1.8 VVT
    Mileage : ... 244K!
    Default Z18XER inlet timing fault
    This is doing my head in. Z18XER. Changed the cam belt a few weeks ago and been getting following snag since.
    After starting sometimes, but especially if restarting from warm, get P0011-61, P0011-66 and sometimes P0170-11. The first two are mechanical errors for the inlet cam. The other is lambda, but probably caused by timing error.
    Have fitted new phaser solenoids and pullies, new lambda, rechecked everything is timed up correctly, new plugs and coil, new cam sensor ( had one so tried in both positions ) If you bump start the car once snag is there it’ll drive fine for the rest of the journey ( or if I reset while it’s still running ) oh - and just tried a flush and oil change too .....
    Latest discovery is the cam position using a diagnostic tool is usually around 140 degrees at idle. ( cross checked on another car as ok ) BUT I did a few starts and on two got around 130 and a code so maybe the cam IS sometimes starting out of position, but why ?
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    62 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    you do know that a cam can be out of spec, because of wear on the cogs? if you haven't replaced them i would look into getting a fresh pair for them... but only after replacing the cam sensor and it still acts up.
    Norfolk
    5 Post(s)
    Engine : 1.8 VVT
    Mileage : ... 244K!
    New cam gear / cogs yesterday ( and sounds good now when working ) . As it was running fine till changed the belt I'm thinking / wondering if I may have stretched a cable removing the rocker box
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    15 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    I find on wiring that if it’s not in the position it’s been laid out for years it throws up faults. Blacky is typical of that the externl bar sensor wiring has to go one certain way or every time you run or start car it’ll throw up faults.
    your only round the corner, if she drives bring her over, can have a coffee and stare at her till she works.
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2021 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
    Apr 2016
    Ipswich
    62 Post(s)
    Mileage : 140000
    Jup i've had the same some cables on the 2.0dti can't be re-routed or not placed back into the exact position.... i had that with the original crankshaft sensor... I replaced it because of that... never had a problem with how i re-routed it as i put the cable in a better position and all in all it gives better access if i have to replace it ever again.
    so it might be the same for you check the cables are in the same position as before (a little turn around might do the trick), worst case replace sensor but from what i can read it actually works just fine.
    Norfolk
    5 Post(s)
    Engine : 1.8 VVT
    Mileage : ... 244K!
    Cheers Jon - may take you up on that but bit busy this week. Will be going travelling tomorrow trrough Sunday. Latest idea is to run a side by side voltage check at the various plugs compared to wifes Astra with the same engine
    Dec 2010
    London
    5 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Quote Originally Posted by JagRigger View Post
    Did you remove cam cover on belt change or just when you changed pullies?
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    315 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Carefull now, always take a chaperone you don’t want his wandering hands going in the wrong places now. Just cos he’s on the list it doesn’t stop him
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Sep 2015
    Norwich
    15 Post(s)
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Quote Originally Posted by Dog_Book View Post
    im gonna come and see you one night sleep with one eye open fat boy
    Norfolk
    5 Post(s)
    Engine : 1.8 VVT
    Mileage : ... 244K!
    Yep - always lock the cams out ( I wrote the flipping how to ! )
  1. Z18XER timing belt balls-up: HELP!!!
    By jaa500 in forum Engine & Drivetrain
    Last Post: 23rd April 2018, 14:47
  2. Multiple Fault codes Z18XER
    By Rich8 in forum Engine & Drivetrain
    Last Post: 21st January 2015, 20:42
  3. timing belt changed with inlet?
    By hairy31 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2011, 13:20
