Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
Thanks. The listing from IM Axle appears to list just about every car as compatible, but the knowledge here on this forum indicates that there are diferences. It is always good to get recommendations as I have had issues with some previous bay purchases.
I swapped the cracked strut with one from a breaker, but bearing is slghtly rough so will need to refit some time later, otherwise the car is still in daily use on short trips and I have not had the chance to get into major works and inspection, in case I can't get it back together in good time. This will happen later. Still has a clunk, so at times so have wishbones and drop links to replace and see whther it is illiminated. When I drop / align subframe / steering will also do ARB bushes too.
