Results 1 to 10 of 13
Thread: Opel Vectra C 2.2 92kw 2004 dti won't start.
    Apr 2021
    Lithuania
    Trim : Universal
    Engine : 2.2
    Default Opel Vectra C 2.2 92kw 2004 dti won't start.
    Hi, So my opel desided not to start. First of all I thought the fuel's pump fuse went bad but sadly no, then I changed all of the spark plugs, fuel filter, checked the injections system everything works flawlessly. Changed the spark plugs and It started, went after an hour give or take It won't start agian. Maybe some of you had simalar problems and knows something what could of went bad? Realy need your help.
    New Member John_Mac's Avatar
    Sep 2020
    Catalonia
    Trim : SW
    Engine : 1.9 CDTI 150HP
    Hi Lukis,
    After all you have looked for I would take a look into the air filter, battery and check the starter motor.
    Sent from my ONEPLUS A3003 using Tapatalk
    Apr 2021
    Lithuania
    Trim : Universal
    Engine : 2.2
    Hi John,
    Starter was restaurated, generator was restaurated.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    the fact that it will jump start suggests the battery is the problem or the alternator being weak and is on it's way out...
    ps your DTI has glow-plugs not spark-plugs...
    Apr 2021
    Lithuania
    Trim : Universal
    Engine : 2.2
    But the deal is it cranks perfectly, it almost tries to start but it fails. Battery is charged checked it.
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    if it doesn't fire up than it doesn't crank fast enough. Diesel engines are self-combusting they don't use the glow-plugs if it is warm enough... unlike a petrol engine that needs a spark to ignite the fuel... the glow-plugs are only used to help heat the combustion chamber up so it ignites the fuel quicker....
    so if you can start it with jump leads of another car... than it's a power problem. If you can only get it to start with a tow start... well than it's probably air that is in the fuel system that needs to be removed, as the fuel pump can't compress the air so in the end it stops the flow of fuel. Have some one turn the switch while you crack each fuel line open to purge the air out of the lines ( make sure you cover them in a big cloth as it will spray everywhere) ... this usually is enough to get the pump to be able to restore the fuel flowing again.
    If the car still doesn't start... their can be only on thing left... timing is off, and with the dti's being chain driven it is a costly affair... and with the prices for the parts most people tend to scrap the car and buy another vectra with a CDTI engine ( these are self bleeding on the fuel- system)
    Apr 2021
    Lithuania
    Trim : Universal
    Engine : 2.2
    Okay, ill try this.
    Apr 2021
    Lithuania
    Trim : Universal
    Engine : 2.2
    Okay tried these but still does not work changed injector seals and rubber tubes, added a valve so that fuel wouldn't go back to the fuel tank, and it still does not start.
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Have you tried to jump start it again after doing the things you have done .If it does i would check that the battery is up to the job or alternator charging correctly.
    Apr 2021
    Lithuania
    Trim : Universal
    Engine : 2.2
    It does not jump start, it tow starts for some reason. alternator and battery is good.
  1. Replies: 1
    Last Post: 11th May 2015, 15:43
  2. Replies: 4
    Last Post: 14th July 2012, 19:53
  3. Clicking noise on start up - 2004 Vectra Energy 1.8
    By Harry Hammer in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2011, 16:29
  4. 2004 07 Opel Vectra C 2.2 HID+AFL
    By omni in forum Vectra C / Signum Troubleshooting
    Last Post: 13th March 2011, 13:55
  5. 2004 Opel Vectra C - Fully Modded
    By 2 Bad in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2010, 19:05
