Results 1 to 10 of 11
Thread: Opel Vectra C 2.2 DTI misfire when engine is cold
    Apr 2021
    Lithuania
    Vehicle : 2004 Opel Vectra C 2.2 DTI
    Trim : Elegance
    Engine : 2.2 DTI
    Default Opel Vectra C 2.2 DTI misfire when engine is cold
    Hey guys! I have a slight problem with my beloved 2004 Opel Vectra C 2.2 DTI. So.. whenever I turn on my engine for the first time (when it's completely cold), it tends to misfire after 10 seconds of running, but the misfire goes away after 2-3 minutes. What I've changed so far:
    - The fuel hoses going to the injectors;
    - The "T" plastic piece thingies;
    - The vacuum hoses;
    - All of the filters;
    - The MAF;
    - The EGR / Elobau are blanked off or.. "reprogrammed", the ECU can't see them.
    I've plugged in my OP-COM and it had no fault codes, the parameters are also fine. When we've purchased (a year ago), it's had lots of old fault codes, one of them was about the fuel pump. But the car starts up fine, it doesn't smoke, it's also chip tuned and after it warms up a little bit (hell, even when it's misfiring), the torque is great. What could be the cause then?
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Dirty tank, fuel, fuel filter, injectors or fuel lines... run a diesel.purge replace the fuel filter and see if it goes away.
    Apr 2021
    Lithuania
    Trim : Elegance
    Engine : 2.2 DTI
    Quote Originally Posted by northpole View Post
    What about water in the fuel filter housing? Aka should I try draining the condensation perhaps?
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    If you drain that you'll have to top it up you can see the state.of the filter... make sure you clamp off the fuel pipes so you have almost no air in it as the dti's are not self bleeding
    Apr 2021
    Lithuania
    Trim : Elegance
    Engine : 2.2 DTI
    Oh, huh.. I'm quite scared to change the fuel filter since I know the problems of 2.2 DTI's, or I know these engines really well.. The fuel filter was changed like 9k km ago..
    Apr 2021
    Lithuania
    Trim : Elegance
    Engine : 2.2 DTI
    https://www.youtube.com/watch?v=ndaW...nel=joez%C3%A9 But this guy changed the fuel filter without filling the housing up with fuel and the engine started right up.. erm..
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    Yeah and than it died off camera I got a dti and know just how annoying it is to bleed them but found that using clamps to close both fuel lines right after the filter greatly reduces the chance of it not starting...
    Alternatively you can crack the fuel pipes on each injector to bleed the air out but that is a messy job.
    Apr 2021
    Lithuania
    Trim : Elegance
    Engine : 2.2 DTI
    What about the glowplug relay? Last summer I've changed all of the glowplugs to new Bosch ones and after that I got a Glowplug relay fault code. I've erased it a few times and now there are no fault codes. The strange thing is that it only misfires ONCE a day, never again..
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    If you turn the key and the glowplug light turns on and the car fires up the relay works... a misfire will not come from that... and if you suspect the glowplig relay... pull them out connect them up, ground the body and turn the key you should see nice glowing tips on each and every one of them.
    Back to your misfire: it could be just water or a dirty filter or a dirty fuel system... it is why insaid run a diesel purge... or a really strong cleaner (a fuel additive like liquimoly diesel purge) and more chuck it in the tank...
    Once that tank is almost empty the problem should.go away... but I'll advise you to change the fuel.fikter after that as it does clean out the complete fuel system including the tank... so the filter will be filthy and it is best to replace it... if you don't want to do it yourself take it to a garage and have it done.
    Apr 2021
    Lithuania
    Trim : Elegance
    Engine : 2.2 DTI
    Can I just use a fuel additive (like, buy a diesel fuel additive and pour it into my fuel tank) and run it until it's almost empty? Will it do the same effect as doing a diesel purge?
  1. OPEL Vectra/Signum 2.2 DIRECT engine, advice please
    By Nicku in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2018, 14:14
  2. Replies: 2
    Last Post: 18th July 2013, 14:41
  3. Slight Misfire & (Intermittent) No Power When Engine's Cold (1.9 CDTI 150)
    By DanR in forum Vectra C / Signum Troubleshooting
    Last Post: 11th March 2011, 21:13
  4. Vectra 1.9 CDTI SRI Nav Engine Misfire issue
    By Joe1 in forum Engine & Drivetrain
    Last Post: 16th September 2009, 10:14
https:www.vectra-c.comforumshowthread.php236785-Opel-Vectra-C-2-2-DTI-misfire-when-engine-is-cold
