Thanks Thanks:  1
Likes Likes:  1
Thread: Keyless entry
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 50k
    Default Keyless entry
    Has anyone ever attempted this? there is a tactile on the dash for it.
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    310 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I just press unlock on my remote to get in, works every time.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  3. Thanks Drogen24 thanked for this post
  4. #3
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    58 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Nope you still need the key in the contact to start it.. so it's pointless, would be different if you install a push start button and make sure the keyless entry actually doesn't need the immobiliser transponder to be in a certain spot but can stay in your pocket... if not.. well than it's still pointless. as you still need to have the key somewhere where the immobiliser can read it.
  5. #4
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 50k
    Quote Originally Posted by Dog_Book View Post
    Yeah mines does that too, but that's not what I asked.
  6. #5
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 50k
    Quote Originally Posted by northpole View Post
    The idea was to install the keyless entry from the Astra's it has a separate module for keyless entry.
  7. #6
    Apr 2016
    Ipswich
    58 Post(s)
    Mileage : 140000
    Than you should've pointed that out... but yeah as i said you'll have to see if you can keep the key in your pocket without the immobiliser having a problem because it can't find the immobiliser transponder...
    And afaik most cars that have proper keyless entry use rf-id systems that replace the immobiliser and transponder setup.
    It still needs to be located in the right spot for it to work though... so why not just use the key?
    On the otherhand if you have access to all the parts for free why not?
    There are aftermarket kits that supply all the parts including a remote key fob that works with that system and can be fitted with a matching blank blade you can have cut to match just incase you need to use the key because of a power problem and need access to the interior.
    But imho it is just a gimmicky replacement of what works just fine.
  8. #7
    Oct 2013
    Derby
    310 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by rozzer2006 View Post
    I thought that’s what keyless entry was? Rather than using a key to unlock the door and activate the central locking to get in you use the remote to open hence keyless entry.
  9. Likes watchman liked this post
  10. #8
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    11 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    It may be a separate module but there is no option for it on veccy for it, weather cim swap would work but you’ll probably need the Astra bcm/rec but would it be compatible I doubt it. Better off asking some off the auto techs who do alarm fittings some do this option with viper system or there is one cheap pke one but think you need an extra module for ignition. And if it works on veccy is another thing.
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2021 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
  11. #9
    Regular Member petrolcan's Avatar
    Dec 2015
    Watford
    20 Post(s)
    Trim : Elegance
    Engine : 1.9 CDTI (120)
    Wouldn't it just be easier to hand the car thieves your keys?
  12. #10
    Sep 2015
    Norwich
    11 Post(s)
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    what part you on about ? Hope you don’t think it’s the vu sensor.
  1. keyless bootlock
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2016, 22:01
  2. Full keyless entry - Can this be done?
    By coldo in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2012, 19:23
  3. do you own a Keyless entry push button start car?
    By hoochydady in forum General Chat
    Last Post: 9th March 2011, 20:10
  4. Keyless Entry
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2007, 09:18
  5. When it says no entry, it MEANS no entry...
    By SignumPhil in forum Comedy & Humour
    Last Post: 14th November 2006, 11:58
