Thread: Rodents Issue 2010 Insignia A20DTH
    Dec 2016
    Sweden
    Trim : Elegance
    Engine : z19dth
    Mileage : 28000
    Default Rodents Issue 2010 Insignia A20DTH
    Hello everyone! Since I'm not a mechanic and the Opel/vaux workshop always tries to screw me over therefor I'm trying this out myself.
    Issues:
    1. Loooong crank time.
    2. Ultra low power immitent.
    Eyes
    1. Rodant **** on the cooler fluid tank.
    Car display:
    1.. ESP Service needed
    2. Service needed
    OPCOM data as follows:
    Total number of fault codes:3
    P2282 - Mass Air Flow (MAF) Sensor Performance - Unknown status (51) - Not present
    P0671 - Cylinder 1 Glow Plug Control Circuit(00) - Present
    P0340 - Camshaft Position Sensor Circuit- Not present
    I also made some readings on other modules which made me a bit scared that all cables has been chewed of by the little devils. I get different readings after clearing/restarting something like this:
    Total number of fault codes:2
    U0073 - Control Module Communication Bus A Off(00) - Present
    U0100 - Lost Communication with Engine Control Module - Invalid Data(71)- Present
    2U0073 - Control Module Communication Bus A Off(00) - Not present
    U0100 - Lost Communication with Engine Control Module - Invalid Data(71) - Not present
    When the code is "PRESENT" on this one I cannot get any mesurement data - this makes me belive that the BCM is the issue or cabling to it.
    Where is the beast located (trunk?) and is there a good overview wireing diagram I can take a look at ?
    My workshop wants to(as a start):Charge me 160€ to do the above readings ( I done them myself)Change the glowies (with pressure sensor) all of them.
    Is it possible to see which version that is fitted without takeing them out, potentially dameging them?
    Glowplugs with pressure sensors are 200€ each.
    You guys helped out a lot with my Vectra C, so I'm sure that you are the best helt there is out there. Give me your best!
    Thank you.
    Dec 2016
    Sweden
    Trim : Elegance
    Engine : z19dth
    Mileage : 28000
    Quote Originally Posted by NeZZeR-N View Post
    Issues:
    Eyes
    Car display:
    2. Service needed
    Thank you.
    To make matters even more complicated I just ran a new scan on the BCM:
    VAUX-COM 120309a - PC based diagnostic tool
    Please add your workshop
    name in the settings window
    VAUX-COM 120309a- CAN Communication Window> 2010 (A) > Insignia > Body > Body Control Module
    Read Info...
    Identifier: 0x0102
    Part Number:13575111
    Software Number:
    Programming Date: 20110316
    Variant programming: 87511141005600D9
    Alpha code: AA
    ECU variant coding: 0x01010125
    Total number of fault codes: 3
    (00) - Not present
    U0101 - Lost Communication with Transmission Control Module
    (00) - Not present
    U0121 - Lost Communication with Electronic Brake Control Module
    (00) - Not present
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    68 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    If i was in your shoes the first thing i would do is get a complete engine loom from a scrapped car and replace the one that is on it right now... since you have a clear indication that there were some rodants living inside the car... also pull out the complete interior and find the nest clean it out and disinfect the car and the area where it's parked... this will keep the rodants away from it...
    or do it the cheaper and harder way and find the problem somewhere in the loom and fix it... but chances are the problem is from coming from chewed through wires
    Nov 2010
    Shropshire
    Vehicle : Insignia Ecoflex
    Engine : 2000 diesel
    No point in fixing the faults while rodents are still trapped in the car. The rodents don't really want to live in your car as there is no food for them, so the best way to get rid of them is leave all the doors, bonnet and boot open. Also try peppermint spray as apparently mice can't stand the smell
  1. Insignia Tow bars - 2010 Insignia Hatch to 2015 Insignia Hatch
    By vxinsigniaboy in forum Insignia car chat
    Last Post: 13th April 2015, 19:29
  2. For Sale: 2010 Vauxhall Insignia CDTI SRI Nav
    By phil67 in forum Cars for sale
    Last Post: 11th January 2013, 19:17
  3. Insignia 2010 - No Camera Option?
    By VXR_DV in forum Insignia car chat
    Last Post: 31st July 2009, 16:51
  4. Rodents under the bonnet...
    By IamtheStig in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 16:01
